Starter wont start?
Old Jun 4, 2012 | 06:59 PM
MyNinja9420's Avatar
Default Starter wont start?
so my stater was working, and then i just heard clicking from the little box on the side of the bike that the red wire connects to (magnetic switch i believe) and it wont turn the bike over, i disconnected the wires and reconnected them, cleaned up the connection surfaces and it still does it, but if i disconnect the wire to the starter and hit the red wire it turns over, is the switch bad? or could i have over heated it? I have had the bike running since ive gotten it, just had to replace the one way gear behind the flywheel, and the bike wasnt starting up so i jus kept running it over messing with the choke and throttle, and it stopped working
Old Jun 5, 2012 | 12:12 AM
The starter relay has a 30 amp fuse. Check that too.
Old Jun 5, 2012 | 01:17 AM
i checked it, the fuse is still good, it just wont work. i found one on ebay, and im curious if 87-09 are all the same part just a different fuse?
FstaRockr Burns
Jun 5, 2014 04:19 AM
IQOUTLAW
Mar 23, 2010 02:33 PM
captainmack
Aug 11, 2009 03:34 AM
remster
Jan 2, 2007 06:52 AM
