speedometer cable coming loose
Old Oct 11, 2006 | 05:23 PM
jamieislimegreen's Avatar
Default speedometer cable coming loose
This is the second time this has happened to me, it coming loose on a long ride.........I even checked it before to make sure it was all the way in.
Someone suggested using locktite on the threads but I am a little unsure. Anyone else have this problem? Any solutions? Thanks.
Old Oct 11, 2006 | 06:19 PM
calamarichris's Avatar
Default RE: speedometer cable coming loose
Which end is coming loose? The end that plugs into the front hub, or the end that threads into the speedo-housing up behind the fairing?
I've had two EX500's so far and they both kept coming loose until using some medium- or low-strength threadlock on the threads. I also used a pair of needle-nose pliers to make sure the upper (speedo housing) end was threaded in tightly enough. If you do this, just don't thread them on too tight or squeeze the locknut/barrel too tightly.
Good luck and let us know how it goes.
-CCinC
Old Oct 11, 2006 | 10:25 PM
my98_500r's Avatar
I have had this happen to me too lately (on the speedo end). Im going to try the locktite trick myself soon.
Old Oct 12, 2006 | 05:25 PM
speedo end, any specific brand you would recommend?
Old Oct 12, 2006 | 06:33 PM
Any kind will do the job. I've got four different grades of ThreeBond, which is available at any dealership.
Just don't use the permanent kind. Medium or Low-torque strength will do the job nicely.
Old Oct 13, 2006 | 02:20 AM
KevyzToy's Avatar
Use blue locktite. It is medium strength. DON'T USE RED. You will never get it off again.
Old Oct 13, 2006 | 07:25 AM
Thanks for the tips, it would suck a little if someone used the permanent and then put it back on wrong..............and yet Im sure plenty of people have, hopefully no Ninja riders though
Old Oct 13, 2006 | 08:16 AM
Even if you cross-thread it initially, the threadlock is like glue and takes a little while to cure. So no stress and no worries. These things are nearly idiot-proof; I'm a pretty ham-fisted clod, but I can still do a decent job of adjusting the valves, synchronizing the carbs and smoking an R1 rider on Palomar Mountain. (haha)
Old Oct 16, 2006 | 05:11 PM
The first time I put it back in I had a little trouble getting it threaded back on right. This time i am having extreme trouble, which actually may be a good thing because I still havent purchased the locktite.......so Im taking this as a sign to get the lock tite first. Once I have the locktite is there anything specific I should do to get it back on properly, last time I just reached in and did it, this time I couldnt do it at all and ended up with 2 nice fat blisters
Old Oct 16, 2006 | 10:42 PM
Aye, installing that thing with the front fairing still in place is awkward. It takes more time and is a PITA, but it will go more smoothly if you remove the front fairing & headlight assembly, which gives you much easier access to the speedo assembly.
The side, fairing-to-tank screws are of very fine thread pitch, so it's best to install them with your fingers at first, to avoid-cross threading.
It takes more time, but look at it this way: this gives you a chance to detail everything!
Good luck & let us know how it goes.
-CCinC
