smell of burn. I scared now.
Old Oct 7, 2006 | 04:51 AM
Default RE: smell of burn. I scared now.
Does the ex have two external oil lines from the head? The banjo bolts seeping causing you you to see the smoke from the exhaust?
Old Oct 8, 2006 | 05:01 AM
Prom's Avatar
did the smoke start before or after you added oil?
Old Oct 8, 2006 | 06:53 AM
RubberxSidexDown's Avatar
Dragone#19: i don't think it has two external oil line from the drain plug. When i took out the drainage plug, I only saw one line of oil comming off.
Prom: yeah it did happen before the oil change. There was two reason why i changed the oil (1) it was about due time to change, (2) i smelled the smoke and thought it was the an oil problem.
Old Oct 8, 2006 | 07:06 AM
ORIGINAL: RubberxSidexDown
No, meant does the ex500 have the external oil lines coming from the heads. I am not an ex expert. My 7 has two external oil lines off of the head, and had a seep from the crush washer which is related to your issues at hand.
Old Oct 8, 2006 | 08:36 AM
dragone#19 i'm lost. I don't understand what those parts are and what they look like or where they are located on my 05. i'm so disappointed that i have another problem to deal with.
Old Oct 8, 2006 | 09:19 AM
ok, no prob, seems like I had better do a google then. And you should check your ride and manual.
Old Oct 8, 2006 | 09:48 AM
my manuel doesn't explain 2 external oil lines. It just teaches me how to change the oil, oil recommnedation, torque setting. filter and so on.
I went here to check for the parts your talking about and still can't find it.
http://www.kawasaki.com/DefaultFrame...OSEVEHICLE.ASP
i posted a picture to show you what i know about oil lines so far. Oil came out the drainage plug and a little came off the filter section too.
I really appreciate your time and help dragone#19 and also everyone else. Thanks in advance.
Old Oct 8, 2006 | 10:51 AM
cool, maybe I am way off here. Time for more searches for me! lol
edit, parellel twins, I do not remember seeing external oil lines. Ok, I am being ignorant.
FOGeologist
Aug 2, 2014 04:09 PM
intense_05_636
Feb 11, 2009 03:49 PM
firstninjabike
Jul 29, 2008 04:39 PM
kawtippn
Jun 10, 2006 10:09 PM
ntence
May 14, 2005 12:11 AM
