Signal Dynamics brake light kit
Old Apr 24, 2008 | 02:07 PM
fnpaulie's Avatar
Default Signal Dynamics brake light kit
I received my Signal Dynamics tail light kit the other day and in reading the installation instructions I saw a warning. Thewarning states that Victory Motorcycles and some Kawasaki's will still not work even with the Dual Load Equalizer.
Does anyone have any experience with this product or SDC?
What is the issue and with which Kawasaki's?
http://www.signaldynamics.com/produc.../tristarxp.asp
Old Apr 24, 2008 | 02:11 PM
Kohburn's Avatar
Default RE: Signal Dynamics brake light kit
you should be fine with the 500
Old Apr 24, 2008 | 03:44 PM
fnpaulie's Avatar
What is the issue?
What chance do I have of any electrical malfunction (if all wiring on my part is done correctly) or a failure of some kind?
Parasitic battery draw?
Old Apr 24, 2008 | 05:36 PM
Kohburn's Avatar
its only if you have a certain type of flasher circuit stock. it just won't work and you'll have to return it to the stock wiring to work. thats the worste case.
Old Apr 25, 2008 | 03:09 AM
fnpaulie's Avatar
The 500 doesn't have this circuit?
Old May 23, 2008 | 01:32 PM
fnpaulie's Avatar
OK, so I installed the unit last night. The dual load equalizer is required at least for my Ninja. The turn signal flashes very fast without it but once added they work perfectly. The instructions are very good but you must follow them EXACTLY and pay careful attention to the steps because one of the steps is counter-intuitive.
Also, maybe using different connectors than the ones supplied might not be a bad idea. They are really bulky.
All in all they work great and I definitely feel more secure in the notion thatthe people following me will see me more clearly whenI brake and because I now have running light turn signals.
Tdizzle
Apr 18, 2009 06:29 PM
jam996
Nov 21, 2008 04:52 PM
SpeedNStylez
Ninja 250R
Aug 9, 2007 04:43 AM
mkn
Aug 2, 2007 03:47 PM
mkn
Jul 6, 2007 12:37 AM
