running funky running good unning funky again
Old Apr 28, 2008 | 05:22 PM
gogi's Avatar
Default running funky running good unning funky again
[/align]
NOT A NEW TOPIC FROM THE SOUNDS OF IT BUT HAVEN'T SEEN ANY DIFINITIVE ANSWER [/align]« on: Today at 12:15:16 pm »[/align]
Quote Modify Remove
[hr]
MY 88 WAS RUNNING A LITTLE CRAPPY (CARBS) AND I HAD MY MECHANIC CLEAN THEM.BIKE RAN GREAT.ALL OF A SUDDEN IT 2 WEEKS LATER STARTED SOUNDING LIKE A 2 STROKE AT STEADY THROTTLE AND WOULDN'T IDLE.I HAD ALREAD PULLED THE TANK CHECKED THE PETCOCK FOR CLEANLINESS AND OPERATION AND THE TANK AND GAS WERE SPOTLESS.DRAINED CARBS AND GAS WAS FINE NO CRUD OR GUNK.MECHNIC LOOKED AT IT SUNDAY AND REPLACED THE VACUUM LINE TO PETCOCK.BIKE SOUNDED FINE IDLED AND REVVED NO PROBLEM.3 BLOCKS DOWN THE ROAD EXACTLY SAME PROBLEM.PULLS STRONG AT HIGHER REVS AND BOTH PIPE ARE HOT.i HAD A SIMILAR PROBLEM WITH 700SC NIGHTHAWK AND IT WAS THE PLUG WIRES.AS IT'S INTERMITTENT I HAVE TO FIGURE ELECTRICAL NOT CARB WHAT ARE YOU GUYS DOING FOR NEW WIRES?
SEEMS TO BE AN ONGOING PROBLEM FOR A LOT OF US.[/align]
Old Apr 29, 2008 | 05:06 AM
calamarichris's Avatar
Default RE: running funky running good unning funky again
Before looking for possible electrical problems, make sure the easy ones have been ruled out.
It's very common when carbs are rebuilt, for the float levels to be upset. The little plastic arms of the float valves are very easily thrown off. I would take the bike to a different mechanic and ask that the float levels be checked.
OR, if you have the service manual and a clear tube, you can do it yourself.
Good luck and let us know how it goes.
Peace!
-CCinC
cliffsta
Jun 27, 2009 12:52 PM
chik636rydr
Dec 30, 2008 06:32 AM
BlackNinjaZX6R
Dec 6, 2008 03:47 AM
Mr. Toad
Feb 2, 2006 06:50 PM
