Please help, need exhaust advice!!!
Old Mar 15, 2007 | 08:05 AM
babypumpkinhead's Avatar
Default Please help, need exhaust advice!!!
Hello, I want to put a 2-1 full system on my 06 ex500. From other posts and other sites, I'm leaning toward Muzzy, but I also want something that retains the center stand, and requires minimal modification as possible.
Also, what jetting changes do you recommend?
Any advice would be appreciated.
Old Mar 15, 2007 | 09:29 AM
Default RE: Please help, need exhaust advice!!!
First question, how are your riding situations? What elevation and ambients are you planning on running?
edit: What do you expect out of your style with the mods to make you happy?
Old Mar 15, 2007 | 09:41 AM
markmeinteil's Avatar
May be wrong here, but I don't think on the 500 or 250 can you put a 2-1 exhaust system on without having to lose the centerstand.
Old Mar 15, 2007 | 05:10 PM
I'm in Wisconsin, riding anywhere from 45 degrees to 90 degrees, low elevation. I am looking to dump the dual system to save some space and weight, I am also looking to make a little bit more noise, and I will take any power gain I get from doing so.
Old Mar 16, 2007 | 02:46 AM
Sounds like mark has a good point also. Wasn't there some fairing mods also when converting?
Old Mar 16, 2007 | 10:52 AM
GC's Avatar
GC
Probably no surprise what I'll recommend....
Sarachu's.....
1. Weight Savings - around 7 pounds less than stock (aluminum)
2. Sound...loud but not too loud imo
3. install - cake, simply replace the old cans with these, takes all of 15 minutes tops
4. No cutting the lower fairing or removing the centerstand
5. No re-jetting - the guys at speed bike racing have tested with all different jetting settings also with and without a K&N filter
verdict is leave everything stock...thats how they race them. (Including a Brazilian Champion rider)
6. Cheap! $298 + around $35 shipping
About the only downside I see for you is if you are really hung-up on the look of a 2-1 system vs replacing the mufflers with these.
Here's the link to check them out
http://www.classicbikes.com/sarachu.html
Old Mar 21, 2007 | 03:07 AM
BLKPEARL's Avatar
ORIGINAL: GC
Sarachu's.....
That's what I used to have on my 500, they'll be loud enough for you. With no other mods needed.
Old Mar 22, 2007 | 03:20 AM
rubix777's Avatar
I think I'm gonna get some sarachu's if in fact they are simple direct replacement for stock exhaust. I've been checking their website periodically for a while now and they seem to always be on backorder for the cheapest aluminum ones.
Old Mar 23, 2007 | 09:24 PM
Chris2skis's Avatar
+1 on the Sarachus. Easy to swap out with the stock cans - I love mine. When I first put them on I thought maybe they were too loud, but got used to them quickly. Check ebay also because occassionally Edgar will put them up on their to sell (or at least he was a few months ago).
If you do a 2-1, be prepared to lose the centerstand, and alter the lower fairing at minimum.
Mart3971
Mar 24, 2011 06:56 AM
Wiliedawg
Sep 16, 2008 05:26 AM
WestOzKLX
Apr 21, 2008 07:23 PM
MAMMOTH
Feb 8, 2008 01:50 PM
grambow
Ninja 250R
Aug 24, 2007 02:59 AM
