need maintenance help
Old Sep 18, 2007 | 03:42 AM
Scrufdog's Avatar
Default need maintenance help
I'll be working on a lady friend's 2000 Ninja 500r tomorrow, need some pre-work info/advice. She just got the bike and it needs help.
Are there any online manuals to check out for it?
Are the spark plugs simple to grab out once the tank is off? Where's the oil filter? Is there an easy way to drain/flush the coolant?
As it is, it only idles with the choke fully open. I already put a bunch of SeaFoam in the fuel tank and let it idle for awhile to get it in there to sit overnight. I found the idle screw on it under the carb, but since the carbs are so gummed up or whatever, I cant tell which way actually makes the idle go up or down.....
Old Sep 18, 2007 | 04:53 AM
Default RE: need maintenance help
hahaha, ya tryin' the pantless trick?
sorry, a funny. But you are not used to carbs/bikes I take it. If a choke is needed to let the ride run, the low circuit and while you are at it, the carb needs cleaned. Floats adjusted and carb synched afterwards. haha, you may have some work on your hands before things are done.
Old Sep 18, 2007 | 11:18 AM
iroc's Avatar
the oil filter is hangin off the front of the bike right behind the front wheel, for the drain plug on the coolant refer here... https://www.kawasakiforums.com/m_169008/tm.htm and the spark plugs u need a deep slim tool to get them i believe...good luck on the carbs lol
Old Sep 18, 2007 | 11:42 AM
jeffzx9's Avatar
Frankly, I'd encourage her to fix her bike. If she wants a "turn-key" vehicle, she needs to ante-up. Don't misunderstand; I'm definitely for helping people. But, I'll help them help themselves by teaching them how to do it. It's the only way they understand, and get out of that helpless mentality. (Otherwise, you'll find yourself on "the hook.") So, what will she do if you're not around?
Teach independence; not dependence.
Old Sep 18, 2007 | 12:51 PM
Scrufdog's Avatar
ORIGINAL: jeffzx9
Thats the plan, but for now I'm only home for a couple days before I disappear out of town for awhile, for work. I'm gonna have er buy the manual for it and such. She works on her car sometimes so she should be able to get the hang of a bike.
And thanks for the info iroc.
Old Sep 18, 2007 | 10:44 PM
iroc's Avatar
np im more than happy to help give back some info for a change
Old Sep 18, 2007 | 11:03 PM
Notstock's Avatar
If she has the shop manual and has a little experience working on cars she should be able to handle the carb cleaning and basic maintenance. Hell if I can do it anyone can and I am as shade tree as they come.
Have her check in here for advice and tell her to use a camera to take pics as she gores along, they arte helpful to to post with questions and for reassembly as well.
Clean carbs, change oil, plugs and radiator flush should take you a long day or day and a half if it is your first time. Tell her get some cold ones, fire up the bbq and have a good day wrenching.
Old Sep 19, 2007 | 12:46 AM
Scrufdog's Avatar
i already changed the oil, plugs and did an 'on vehicle' carb clean. It helped for awhile, now its doing something new.
Earlier today I was riding it and it seemed to be doing ok. I rode it a little while ago however and something new has started while riding. I'll be accelerating on riding steady and then the RPMs drop and twisting the throttle does nothing. If I bounce on the bike like a freakshow it will go again for about 10 seconds then starts loosing RPM, boing boing...better. Seems the bouncing helps, so I'm figuring something big came loose in the carbs and it causing a float to stick....sound about right?
Also, when I take this carb out tomorrow, what is serviceable without buying a kit? What gaskets are rubber/neoprene and what can be siliconed up? If your really bored feel free to drop some links with pics or something. She'll be over here tomorrow night, so she can help.
Thanks again
Old Sep 19, 2007 | 01:03 AM
iroc's Avatar
omg wow that sounds freakishly similiar to my bike ....when i twisted the throttle ...nothin, like it was already dead...my problem was 1 of 2 initial things....1 the little black box-ignitor box......2 my fuel feed needed rerouted ....im not implyin either is ur problem but the box was quite an adventure to say the least ...anyways good luck
Old Sep 19, 2007 | 11:29 PM
dragknee's Avatar
ORIGINAL: Scrufdog
Thanks again
the running only on choke sounds like a clogged pilot jet. you cant really clean them "on bike". you need to take them out and make sure you can see through them.
you shouldnt really need a kit for anything, unless something is broken.
as for the float, sometimes pieces of the rubber fuel line get cut off when you jam the line up onto the petcock nipple... they will hold the float valve open.
gaskets, you shouldnt need any unless the bowl gasket is damaged
