Need help
Old Apr 7, 2007 | 11:55 PM
sheric's Avatar
Default RE: Need help
So the general consensus is that I should change my spark plugs and then see if the problem is solved?
Old Apr 8, 2007 | 01:03 AM
lemac's Avatar
Thats where I would start
Old Apr 11, 2007 | 02:49 AM
kali_ninja500's Avatar
i also have the 06 with about 3K miles on it...... so far no problems like you have described....
good luck and make sure to let us know what's what in case it's something that happens to not only your bike.....
Old Apr 11, 2007 | 07:48 AM
dilysi's Avatar
dose your ares use the achole enriched fules? if so there is a chanch of the fules pulling moisture out of the air and settleing to the bottom of the tank and or carb boul. if you change your plugs and the problem presist sifan out the botom of your tant into a clear container let it settle if it seperates into two or more layers than you have a water ishue adding dry gas wount fix the problem if you have achole inriched fules.
Old Apr 11, 2007 | 03:39 PM
calamarichris's Avatar
Hey Sheric.
If your bike will start and idle perfectly with no choke, then someone has been tampering with the jetting and/or pilot screw and it is running too rich.
Are you the original owner or did you buy the bike used? If so, do you still have access to the seller? Can you ask him if he made any changes to the carburetors?
If a bike starts and idles fine with no choke, it is too rich.
-Chris in C'bad
Old Apr 11, 2007 | 10:55 PM
rubix777's Avatar
it shouldn't be able to cold start right up without the choke. if it does, like what calimarichris said,it'll be running rich.
that extra fuel it is dumping in to help in the cold start will be bad when it eventually warms up due to running rich.
Old Apr 20, 2007 | 10:59 PM
sheric's Avatar
i bought it used, but from a dealer. i'm going to take it in in a few days for the 4K tune up anyway, so i'll ask them to check everything out and i'll post about what the problem was.
thanks for all the help
Old Apr 21, 2007 | 12:01 AM
Evergreene529's Avatar
Its your jets, had the same thing with my 250. somebody messed with em. I think if you also turn screws all the way in and... 1 n' 1/4 out? not sure, don't listen to me then [8D]
But yeah, dealer should have it tuned for you then.
Old Apr 26, 2007 | 12:05 AM
sheric's Avatar
i was quoted $250 to have the carburator re-jetted... does that sound fair or should i just go to the dealer and have them do it instead?
Old Apr 26, 2007 | 01:37 AM
The dealership will restore your stock settings for MUCH less than $250 and your bike will run great and last longer.
If you don't want to get the Factory Service Manual and do it yourself, I'd take it to a dealership.
Good luck and let us know how it goes.
Peace!
-Chris in Carlsbad, CA
