Internal lighting in instrument cluster
Old Aug 18, 2007 | 02:14 AM
Kawacon's Avatar
Default Internal lighting in instrument cluster
Does anyone have any experience replacing lights inside the instrument cluster?
Is it possible, and is it difficult?
Old Aug 18, 2007 | 03:52 PM
Kawacon's Avatar
Default Internal lighting on instrument cluster
Has anyone had experience changing light bulbs inside the instrument cluster?
Is is possible? Is it difficult?
Old Aug 18, 2007 | 08:44 PM
calamarichris's Avatar
Default RE: Internal lighting on instrument cluster
The good news is that the bulbs are cheap, even if you get the OEM bulbs from the dealership. The bad news is that they're a PITA to get at.
You'll have to remove the front fairing:
~remove the two rearview mirrors
~loosen the two downward-facing 10mm bolts
~and the two downward-facing, fine-thread phillips screws that mount the fairing to the gas tank.
Now, looking at the underside of the instrument cluster, there should be two 8mm nuts holding it to the steel subframe. Just loosen those, lift the cluster and swap the bulbs. Reassemble reverse of tear-down. Might as well take your time and clean everything really well while you have it apart.
Good luck and let us know if any questions come up.
Peace!
-CCinC
Old Aug 18, 2007 | 09:47 PM
Kawacon's Avatar
Whoa! I just priced the OEM bulbs at $3.73 x 8 = $29.84![:-]
(3 each, #92069, plus 5 each, #92069A)
Maybe I can identify the bulbs after I pull them out and by them cheap, locally.
I'll let you know what I find out.
Old Aug 19, 2007 | 02:57 AM
dragknee's Avatar
hey, i think i have most of them from my stock cluster sitting around, id send them to you for free PM me
Old Aug 19, 2007 | 03:27 AM
Oh jeez! Why didn't I think of that!? I've got TWO instrument clusters in my garage right now. <forehead-slapping smiley>
Old Aug 26, 2007 | 08:07 PM
dragknee's Avatar
hey i dunno if you got my PM or not, but i cant find them
maybe chris will be kind enough to send you some
Old Aug 26, 2007 | 10:11 PM
Kawacon's Avatar
Yes, I got your PM dragknee, I just had not replied.
Hey, thanks for checking on the bulbs for me.[sm=smiley20.gif]
I will check with Mr. Ninja 500 (Chris).
Old Sep 9, 2007 | 12:18 AM
Kawacon's Avatar
I stopped by an auto parts store and bought standard automotive instrument panel light bulbs for $2.88 a pair. They work just fine, at less than half the cost, and no shipping charge.
ortme
Jun 11, 2018 03:09 AM
TheKawiKid88
Sep 17, 2013 03:30 AM
Brieninsac
Apr 6, 2012 12:25 PM
deej
Jul 10, 2008 06:12 PM
SERGE
Mar 28, 2007 06:34 PM
