i was recently given a 91' 500r i can't seem to figure out where these hoses go under the tank?
Old 05-13-2007, 02:37 AM
the_sd_gorilla's Avatar
Default i was recently given a 91' 500r i can't seem to figure out where these hoses go under the tank?
Ihave been trying to put it back together but i need your help?
Ihave posted4 pics
There is a black hose from the gas tank valve that i need to know where it goes, as well as a clear tan hose from a twistable bar at the bottom of the intake with a hose clamp on it.
There is 3 spots for a hose but i only have 2 hoses and i don't know where they go?
The only spot that the tank hose will fit is on another twistable pipe above the one with the clear tan hose on it.
Any thing you would have to add would help me greatly!!
[IMG]local://upfiles/5471/A6C0D048B3084236A0C3E421C36AD166.jpg[/IMG]
[IMG]local://upfiles/5471/C01546BA80274C47AB987461D541CFC1.jpg[/IMG]
This is just behind the carb, on the other side there is a black hose that goes to the (resivoir?) tank.
[IMG]local://upfiles/5471/5BFA883EFDF643CBA96BD79C34361113.jpg[/IMG]
This is the spot for the tank hose, and the next pic is the hose.
[IMG]local://upfiles/5471/4F77C4803E464A4ABCD5CDF588921A40.jpg[/IMG]
Tank hose
Old 05-13-2007, 07:06 PM
calamarichris's Avatar
Default RE: i was recently given a 91' 500r i can't seem to figure out where these hoses go under the tank?
Hey SD. (Does the SD stand for San Diego or for South Dakota?)
The little intake port on the left side should be connected to the fuel petcock. The vacuum exerted by the intake activates the diaphragm petcock (heh heh... "Diaphragm petcock" heh heh.) and allows fuel to flow.
The little intake port on the right side should be connected to the top of the vacuum hose assembly that is also connected (with thicker hoses) to your airbox and to the fresh-air inlets near your exhaust headers.
If the "SD" stands for San Diego and what I've just said doesn't make any sense, let me know where you live and I can show you a working example.
Oh yeah... and here's a photo of an '02 (which admittedly might be slightly different.):
Good luck and let us know how it goes.
Peace!
-Chris in Carlsbad
Old 05-13-2007, 09:37 PM
SD is for South Dakota straight up!!
I know i am a retard(and that's not because i'm from South Dakota)but i go by, that black thing, and that other thingiehoocher.
here is a diagram, this is high quality!!(and a pic of me)
canI use regular antifreeze in this the radiator??
[IMG]local://upfiles/5471/E1FA7A731CC94B52ACB69162482E7FDE.jpg[/IMG]
[IMG]local://upfiles/5471/9640AC8F0D224B7081B9FA4E57EAEEAD.jpg[/IMG]
crf230
05-16-2009 06:42 AM
jengreen
Oncycles.com Motorcycle Riders Mall
04-03-2009 08:42 PM
Funkdock
05-13-2006 10:46 AM
ZX12Rider
Joke section!
02-16-2006 10:30 PM
Quick Reply: i was recently given a 91' 500r i can't seem to figure out where these hoses go under the tank?
