Clutch Cable
Old Feb 1, 2012 | 12:55 PM
nuzzy's Avatar
Default Clutch Cable
Hi Guys,
I was wondering if there's a way to tighten the clutch cable on my Ninja 500r so that it'll grab sooner? Right now, it's start to grab when i'm almost done releasing the clutch, which feels a bit too far for me.
Thanks
Old Feb 1, 2012 | 04:22 PM
jeffzx9's Avatar
Nuzz, check both ends of the cable (lever end and engine end). There should be either a threaded adjustment wheel coming off the clutch lever, or some manner of adjustment on the engage/disengage pivot coming out of your engine. Make sure your actual cable is in good shape; sometimes (lube) neglected ones can get very brittle. Keep 'er slick.
Old Feb 7, 2012 | 01:32 AM
Is there a 5 way adjuster **** on the bar as well?
Cables do stretch and do need maintained, but normally 2-3mm clutch lever free play is recommended.
Old Feb 7, 2012 | 02:03 AM
BleednGreen68's Avatar
Just a lil play in the lever will do ya. That will tell ya that its in engaged all the way. Nothin worse than a super tight clutch lever. I like some wiggle room.
jcbowling1985
Ninja 250R
Oct 19, 2012 05:35 PM
deej
Jun 2, 2008 10:46 PM
davehayward1
Sep 24, 2007 04:20 AM
FM_Thumper
Apr 13, 2006 12:15 AM
DarkTari
Aug 2, 2005 11:01 PM
