95 500 not running right
Old Mar 18, 2009 | 09:20 PM
joflo1980's Avatar
Default 95 500 not running right
i switched to my res tank and when i filled up and switched back it started runnig wierd in first gear its hard to take off and i sputters what could it be any advice?
Old Mar 18, 2009 | 10:46 PM
Most likely water and debris in you floats from scavenging the remaining gas and water from the bottom of your tank. Drain the bowls firstly, easy to do. For ****s and grins, take a peak at the drained contents in the glass jar that you drained the bowls into. What do you see?
edit: Welcome to KF and vote for the green bike in the bike of the month. lol https://www.kawasakiforums.com/forum...ad.php?t=27221
Old Mar 19, 2009 | 01:28 PM
+1^^^ But if the gas looks clean you might debris in your petcock screen.
Old Mar 19, 2009 | 10:36 PM
joflo1980's Avatar
thanks,this site is great i look forward to being a part of these forums i was actually in the process of painting this bike it is now primed.whan i was taking everything off i accidently cut a blinker wire...could this problem be from charging system ? checked the gas there was no particles anymore i guess it had already sucked everything up..do i need to change the spark plugs and clean everything out now ..what all could have got trash in it? i havent checked the fuel filter yet when it drives it goes up to 4-5 rpms then shoots all the way down then shoots back up and jerks all over the place .....thanks for the advice
Old Mar 19, 2009 | 11:54 PM
Definitely fix the electrical first. A lack of juice will cause a bike to flat on its face. Then go to the fuel setup after that. Let us know
Shrekster1
Jul 9, 2009 02:18 AM
mrvalle2
Jun 15, 2009 03:58 AM
Moe Szyslak
Dec 18, 2006 05:53 AM
firstninjabike
Oct 17, 2006 02:44 AM
AKRider
Jul 31, 2006 04:41 AM
