Oil Light....
How long should it stay on when you first start the bike?
The past couple days it seems to stay on longer then it used to. It's only like 5 -10 seconds. The oil level is perfectly fine on the bike so I know it's not that. And I changed the oil about 600 miles ago.
Or is this normal. The only thing different that I have been doing is holding in the clutch when it's warming up so the bike doesn't jump forward as much when first going into first gear.
What are you doing when you check the oil? Its my understanding that any change from normal shut off on the oil light indicates a problem. You may try going back to the old way of starting and see if its what you were used to. If it is then I wouldnt worry.
You are checking the oil level while the bike is fully upright, right? The strange thing I noticed when breaking in my 250 was the oil light seemed to stay on forever at start-up. (Over five seconds.) Now, after 3,200 miles the light goes out after the first few seconds of running.
It only jumps forward on the first start up of the day. As soon as I go to the first stop sign it doesn't jump forward. I am going to recheck the oil level. But whenI checked after work let the bike sit for 15min then put it level and the oil glass was full.....
Ok I just counted stayed on for 13 seconds. Oil level is full. When the light went out the oil level was still 3/4 full then after it warmed up it was about 1/4 full while idleling.
I guess this is normal the bike still seems to run good.
That doesnt sound normal. And when the bike is running the site glass should be empty, if not its either overfull or you have something blocking an oil path or a problem with the pump or filter.
Ride the bike 5 min dont just let it idle or it will foul the plugs. Put it on the centerstand take your gear off and check it about 5-10 min later the level should be no higher than the top tick mark on the site glass which is about 3/4 up.
ORIGINAL: dilysi
the bike jumps forword when you first put it in gear? when was your last cable adjustment the sirves limit is cinda tight
ORIGINAL: mnosbor
