No guages, lights etc....
Old Jun 24, 2007 | 08:56 PM
ldaniels683's Avatar
Default No guages, lights etc....
I have a 88 Ninja 250. Bought a few months ago, realized I was missing some vitals (fuel tap) and have been working on it instead of enjoying it ever since. I have an issue with my wiring. The bike will start up and run, etc, but I have no headlight, turn signals, horn, guages, etc. I was wondering if there was something simple I was overlooking on this. Checked all the fuses, all are good. I have the wiring diagrams, and everything seems to be in place with exception only to the turn signal wires. There are two wires connected into the main harness, where both ends are disconnected, but from my manual that seems to be normal. Any help anyone could give would be much appreciated.
Old Jun 24, 2007 | 10:33 PM
markmeinteil's Avatar
Default RE: No guages, lights etc....
Not sure what to say about that. Have you checked for any corrosion on all the connections? Or, maybe you have a bad relay somewhere.
Old Jun 24, 2007 | 11:15 PM
mikeyntnc's Avatar
sounds like a main switch somewhere has given up . You traced all the wiring to all relays , switches and such ? Doesn't really sound like a wiring problem unless a main 'hot' has broken . You got a meter to check continuity with ?
Mad1111
Apr 7, 2009 05:07 PM
firsttime
Ninja 250R
Oct 25, 2007 12:49 PM
Motopsychoz
Aug 15, 2007 04:49 AM
Hermolicious84
Jun 13, 2007 05:02 AM
damianmantis
Nov 13, 2006 06:29 AM
