Minor Problem...
Old May 15, 2006 | 01:18 AM
tomfohr's Avatar
Default RE: Minor Problem...
Okay well I let it sit on a charger until the battery was full charged.... took it out this morning around a couple blocks and it died out again... anyone got any other suggestions.... im getting really iritated.
Old May 15, 2006 | 04:20 AM
BigRig18Wheeler's Avatar
when it died, did you check for spark?
Old May 21, 2006 | 08:36 PM
tomfohr's Avatar
Okay, I did a little bit more trouble shooting because its nice out again and I really wanna get my bike going again. I rode it until it started to die and then right before it died I put the choke on and it didnt die, it reved back up but as soon as I would start to pull the choke away or start going by easing out the clutch, it died... Now this is leading me to believe it is something with the carborator... Any suggestions. I have a mechanic I plan to take it to, I just have to find a way to either fit it in a minivan or find somone with a truck.
Old May 22, 2006 | 07:51 AM
Yup...carb problems...eeerrrrr...Sounds like it's time to yank 'em off and do a good cleaning..Your fuel filter is good right?
Old May 22, 2006 | 08:34 PM
kwninja88's Avatar
how does it idle?
Old May 23, 2006 | 01:13 AM
tomfohr's Avatar
Well when I first start it up, it idles fine. But after it has died, it doesn't idle, its hard to even keep it running without the choke on full.
Old May 23, 2006 | 07:10 AM
kwninja88's Avatar
This does sound like a carb problem. You may want to check the position of the carb float bowl, the jet, and the cleanliness of the fuel filter. The air filter may be a good thing to clean too if that hasn't already been posted earlier. Also, when it runs before it stalls and is fully warm is the idle speed correct (1200-1400rpm)?
Old May 23, 2006 | 07:12 AM
kwninja88's Avatar
BTW - how was your spark?
Old May 23, 2006 | 08:49 AM
tomfohr's Avatar
I have yet to test the spark due to the fact that I do not have a spark tester. I am taking the bike to a mechanic tomorrow and he is going to diagnois it for free. If it is something simple, I will fix it. If not, looks like I'm paying him to do it.
ahnh666
Oct 27, 2012 01:24 AM
bigbrew
Apr 28, 2007 12:22 AM
Q500R
Ninja 500R
Feb 17, 2007 03:30 AM
BigO
Dec 8, 2006 10:09 PM
MIPLAYSTATION
Jan 5, 2006 02:36 PM
