loss of creature comforts...
Old Mar 2, 2007 | 09:27 AM
flowerpowerlover's Avatar
Default loss of creature comforts...
as i have ridden much more than i have actually set aside time to learn about the details of motorcycle anatomy, can someone tell me about the parts on a 250r that does not have to be there? - this is for a streetbike...so the obvious race reduction stuff wont apply. ex. signals, mirrors...
thanks!
Old Mar 2, 2007 | 09:36 AM
markmeinteil's Avatar
Default RE: loss of creature comforts...
You could turn it into a streetfighter machine and take off all the fairing![8D] Otherwise, about the only parts you could remove or change would be: removing the centerstand, changing the exhaust to a lightweight muzzy 2into1 system. The 250R is so basic that just about everything on it must be there for it to function.
Old Mar 2, 2007 | 09:38 AM
suprakawigrl's Avatar
welcome to KF. I used to own a 250, the only thing I removed was the fender. Other than that the bike is already pretty light. I did put smaller blinkers on but that was about it because I bought a 7R within 9 months.
Old Mar 2, 2007 | 04:42 PM
jazzman's Avatar
you can cut off the rear fender, alot of people do that... but won't really gain you much weight.. maybe a pound? I say easist way to cut some weight is to go on a diet!
Old Mar 4, 2007 | 10:08 AM
ah, the exhaust...i am truly in a quandrie sp? do i go with the 3.5lb cf Muzzy with a high matanience attitude problem or do i go with the TBR dual the weighs 5.95lbs but is much less drama?
i was thinking about the streetfighter route but am not due to lost of aerodynamics for freeway driving...
Old Mar 5, 2007 | 12:38 AM
I did not see if the Muzzy came in a dual full setup or not.
Old Mar 5, 2007 | 12:55 AM
it doesnt and thats why it seems to be the lightest option. TBR has a dyno sheet for their application and it showd that with a stage 1 jet kit 1.5hp gain was achievable. Thats probably comparable to the Muzzy but alas it is also 2.5lbs heavier.
Old Mar 5, 2007 | 01:12 AM
I was thinking that a 4 into 1 full exhaust really puts the powerband up high. Not sure if the parallel twin can stay in the powerband with that combo and be streetable. Just a question mark for me as well.
kmacloud
Dec 30, 2012 07:38 PM
Worlok14
Oct 1, 2009 01:57 PM
lyle147
Sep 22, 2006 11:14 PM
shon
Jun 14, 2006 04:49 AM
jman7680
Jun 8, 2006 08:47 AM
