Just put on an EX 500 shock
Old Oct 8, 2007 | 09:39 PM
mikeinRichmond's Avatar
Default Just put on an EX 500 shock
It bolted up like a charm and was very easy, only question is does tightening down on the adjustment net, thus compressing the spring, increase or decrease the sag measurement? Also the FAQ on ninja250.com said to measure with the bike on the centerstand without rider, then to take it off the centerstand and sit on it for the next measure. Sound right? Just making sure I wasn't missing something. Thanks
Old Oct 9, 2007 | 07:41 AM
Default RE: Just put on an EX 500 shock
yes, static sag and rider sag with gear.
Old Oct 11, 2007 | 04:24 AM
aho's Avatar
aho
how does it feel? how much did it cost you? im thinking about upgrading if its not too expensive or difficult...
Old Oct 12, 2007 | 11:20 AM
So far it works great and I'm very happy with it. $70 on ebay with $20 shipping and it was off an '04. I've seen it cheaper but the bikes were usually 8-10 years old. Decided to go this route since it bolts right up, instead of a SV650 which might be a better overall shock but needs modification to get on.
The FAQ at http://ninja250.com tells exactly how to do it and it took maybe 20 min. total. Good luck!
Old Oct 12, 2007 | 11:41 AM
jeffzx9's Avatar
My only quibble would be thewear on the shock (i.e. mileage; not necessarily date of manufacture.) If it's been ridden alot, you may want to get it revalved or at least checked before installing. An '04 should be pretty safe, though.
Old Oct 13, 2007 | 05:53 AM
If you are able to set sags and save $30 bucks, that is great. As long as you are comfy with your ride.
mandark
Nov 17, 2008 09:09 PM
BIG V
Apr 20, 2007 07:12 AM
TheMaverick
Mar 17, 2007 12:37 AM
kali_ninja500
Ninja 500R
22
Nov 26, 2006 02:54 AM
bella lugosi
Aug 21, 2006 05:56 PM
