Fairings - 08 on the 07?
Old Jun 19, 2008 | 06:21 PM
izel's Avatar
Default Fairings - 08 on the 07?
is it possible to take the front fairings off a 2008 and put them on the 2007 model? I want to get the front look but wasn't sure if they fit on the 2007? I'm going to think positivitely on this one.
Old Jun 19, 2008 | 06:34 PM
markmeinteil's Avatar
Default RE: Fairings - 08 on the 07?
If it is possible, you would also have to change the headlight, gas tank, lower fairing, etc. Every piece on the '08 has a different shape to it, therefore, if you replace one part, you will have to change the other pieces so they all "fit".
Old Jun 19, 2008 | 07:28 PM
94Ninja250's Avatar
I'm thinking that the mounting brackets will be in completely different locations. If you were even able to attach one / any, it'd look like Frankenstein's monster.
Old Jun 19, 2008 | 11:46 PM
Whapt's Avatar
I may be possible with some wok to get everything to fit let alone the price after you buy everything you need may be a little expensive
Old Jun 22, 2008 | 08:42 AM
sombo's Avatar
Couple of things to think about with this idea.
First, not a single piece of body work from the '07 was used on the '08. Second, the frame was changed slightly to make it more compact and handle better. Third, the angle of the front forks was changed by 1 degree for better handling. These three things combined would make it either: a)impossible to do, or b)too expensive to bother with since you might spend almost as much as the bike is worth to do it.
Most likely you'll just have to upgrade to the '08 model if you can find one (good luck on that >.&gt.
Old Jun 22, 2008 | 10:10 PM
dillon's Avatar
ORIGINAL: sombo
thats perty much what i was thinking also...
Old Aug 24, 2025 | 06:07 AM
Dbovey64's Avatar
Default It has been done
On Facebook market place someone put 2008 fairings onto a 2007 ninja 250r
Dragon
Sep 13, 2005 05:18 AM
firedog
Jul 20, 2005 04:08 AM
zxta6rr
Jul 16, 2005 02:07 AM
Hic01
Jul 12, 2005 03:27 AM
Richard
Apr 26, 2005 06:59 AM
