electrical problems?
Old Sep 21, 2009 | 04:21 PM
Warren's Avatar
Default electrical problems?
I have a 2005 ninja 250 1984 miles on it. It has been sitting for 2 years, anyways trying to get some life back into the thing, cleaned the carbs did all that but the only way i can get the engine to start is if i give it full throttle then i hit the starter it revs up to about 6k and as soon as i let off the starter the engine dies. im thinking i have a short or something, any info will help. Thank you.
Warren
Old Sep 21, 2009 | 04:51 PM
95451's Avatar
Welcome To Kawasaki Forums.
Turn On Same Tunes And Enjoy The Ride.
Theirs a lot of Good Members Here and they will do there Best to Help You out with Your Questions. Sometime It Takes A Little Longer Then Others. So, hang-in there. Have Some Fun
Old Sep 22, 2009 | 01:29 AM
Warren
Welcome to KF.
I would start over again on your carb cleaning, adjust the float height to the recommended settings, verify all hoses and all parts are tight and clean. Check your choke cable adjustment, and the fuel petcock cleanliness. Then I would toss my gauges on to check the synchronization of the carbs. Just K.I.S.S. Oh, you do have a clean fuel tank with good gas I would imagine? Good luck
Old Sep 22, 2009 | 03:14 AM
c_m_shooter's Avatar
Your pilot jets are still plugged. Dig back into the carbs.
Old Sep 22, 2009 | 08:53 PM
Warren's Avatar
Thank you both for the help i will rip my carbs back open and go to town on them.
holios551
Feb 16, 2013 01:48 AM
rey739
Jan 12, 2008 05:37 AM
ruffryda
Ninja ZX-9R
Jul 21, 2007 05:47 AM
ninja_jim
Feb 22, 2007 07:30 AM
kegger11
750
Jan 2, 2007 07:21 AM
