Edit: (STARTED)
I set the clips on my needle jets higher to close off the fuel from the main jet more, which has helped a bit, I think my diaphram cracks may be worse than I thought so when I gather smoe more money I'll probably replace them. That would be the only vacuum leak I could think of that would cause that, I don't think the pod filters would have anything to do with it.
One of my diaphragms was cracked; they cost $119 new from the dealer. I was able to clean it off using rubbing alcohol and repair it using black silicone. It worked well, might wanna give it a try to save you some bucks.
jesus... yeah i knew they were expensive just buy the crazy way they look manufactured but damn that's a lot. I guess I'll use your method. Where do they sell black silicone?
sobster88
Ninja 250R
Feb 19, 2008 10:58 PM
