drain fuel
Old Jul 18, 2008 | 07:45 PM
schneedrache's Avatar
Default drain fuel
K, so I'm moving and the moving company wants my gas tank empty, what is the easiest way?
Old Jul 18, 2008 | 09:26 PM
hayes077's Avatar
Default RE: drain fuel
pull your fuel line off the carburator and put a gas can under the loose end of the hose. then turn your fuel selector to prime. you should probably have the gas cap open so it doesnt create a vacuum inside the tank.
Old Jul 19, 2008 | 01:11 AM
kevhamm's Avatar
that
OR
ride it till its empty.
ride it to your new place.
let it run till the gas runs out.
OR
what hayes077 said
Old Jul 26, 2008 | 01:42 PM
so by the way, this was the biggest pain ever to do. I cut the zip tie at the pri/sec switch and pulled off the tube thinking that the gas would just nicely flow. WRONG. the bike has to be on for fuel to flow, so you have to turn on the bike and then hold the gas can, or in my case a water bottle, under the switch. Then when the bottle is full re attach the tube. if you turn off the bike there may not be enough fuel in the carbs, which I didn't Think of so I had a few issues.
clgdswr
Sep 7, 2009 01:10 AM
doitinthewoods
May 22, 2007 03:14 AM
DJFields
Dec 16, 2006 02:45 AM
markturbo
Dec 12, 2006 03:26 PM
Notstock
Mar 8, 2006 03:26 PM
