Bar ends
Old May 7, 2007 | 02:34 AM
xxbambam2xx's Avatar
Default Bar ends
Ok well im new so, but i cant get the bar ends off. I habe tried everything. So any ideas would be appreciated. Also does anyone know where i can get a pair of used ones. I have already ordered new bar ends but just cant get the new ones off to get the new grips on...
Old May 7, 2007 | 03:12 AM
jellyfish's Avatar
Default RE: Bar ends
Well those bolts on the end are held on with red loctite. Nasty stuff... I get them with a hand impact with the right size phillips head socket.
God Luck!!
Old May 7, 2007 | 03:31 AM
what about just drilling the screw out since i already have new ones with new hardware
Old May 7, 2007 | 04:15 AM
jellyfish's Avatar
The threaded insert stays in the bar and the threads are quite long like 2 inches. If you have the ability to drill it out and not messing up the threads go for it.
http://faq.ninja250.org/wiki/Removin...acing_bar_ends
HAVE FUN!
Old May 8, 2007 | 05:25 AM
mnosbor's Avatar
Heat and a #2 drywall bit, I used a blow dryer because I didnt want to melt the throttle part under the grip so I didnt use a heat gun.
However to replace the grips you dont need to remove the bar ends. You have to cut the end of the newgrips open anyway, they dont go between the end and bar.
Just cut the old grip off carefully not to cut the handlebar then cover it with aqua net extra holdharspray slide the grip on, wait a few hours and your good to go.
Trust me hairspray is the way to go.
Old May 8, 2007 | 05:42 AM
but i already bought new bar ends because mine are striped and stuff and all scratched up but if worst comes to worst i will use your way thanks anyways and any help appreciated
350ZX6R
Mar 27, 2007 08:29 AM
Ratkiller
Feb 9, 2007 06:09 PM
mikedrinfla
Jan 15, 2007 08:15 AM
zx636
Mar 21, 2006 09:14 AM
05_ZX636
Nov 18, 2005 11:17 AM
