01 Ninja idle rpm's ?
Old May 23, 2007 | 10:46 PM
Phil2801's Avatar
Default 01 Ninja idle rpm's ?
Hey guys , I just picked up an 01 ninja and I was wondering what everyones bike idles at usually . When i fire mine up it normally sits at 3k ish or so rpm's , Is this unusually high or about average ?
Old May 23, 2007 | 10:53 PM
markmeinteil's Avatar
Default RE: 01 Ninja idle rpm's ?
That's a bit high. There is an idle adjustment **** on the left side, sort of by the fuel selector lever on the tank. If you turn it counterclockwise, that will lower the idle. The bike should be set around 1,300 RPM's.
P.S. Make sure you only adjust the idle once the bike has fully warmed up, and without the choke on.
Old May 23, 2007 | 10:58 PM
drb1984's Avatar
after i went for a long ide today i was idling at a red light and it was about 2k. I thought this seemed a little high. I have 350 miles on my 07 and I just scheduled the first une up for next week so I'll have them adjust it.
Old May 23, 2007 | 11:25 PM
Phil2801's Avatar
Ya seemed a bit high , When im turning that bolt is it ok to have the bike on or should i turn it off , Also about how long should i let the engine warm up ? 10min or so ?
Old May 23, 2007 | 11:44 PM
Ten minutes is good. It really doesn't matter if the engine is running while you turn that adjustment ****. Just turn it slowly until it gets down to the desired RPM's. (VERY easy to do.)
Old May 24, 2007 | 12:04 AM
Phil2801's Avatar
Awsome , Thx a bunch for your help , Its now running just under 1500
Old May 24, 2007 | 12:14 AM
Glad I could help!
Old May 24, 2007 | 02:03 PM
Bluebeast's Avatar
yea 1500 rpms is good. I usualy run my 636 about 1300rpms.
Old May 24, 2007 | 02:21 PM
Evergreene529's Avatar
vacuum hoses, check them. Don't touch that idle screw unless shes wamed up first.
mvandeusen600
Sep 1, 2009 05:22 PM
rkelley548
Jun 17, 2009 07:43 PM
8cuttlefish8
Mar 22, 2009 03:14 PM
JETHRO980
May 16, 2007 10:21 PM
jayden
Ninja 250R
May 1, 2006 04:24 PM
