why should I choose kawasaki
Old May 16, 2005 | 07:08 AM
shawn_460's Avatar
Default why should I choose kawasaki
I want a sport bike why kawasaki r6 why not another type of sport bike. What I'am I getting from kawasaki that I'am not getting from honda rr, yamaha r6 or gsxr 600. For my first bike I want something bad and fast and safe. Can some one break it down for me on these bike's.
Old May 16, 2005 | 01:25 PM
Violet_Vixen's Avatar
Default RE: why should I choose kawasaki
Well to get you started, here's some info. I'd advise against a new bike, even though that's what I've given you info on. For the most part, an older bike will have the same specs. More later, in a hurry.
Yamaha R6
http://www.yamaha-motor.com/sport/pr...s/8/specs.aspx
Suzuki GSZX-R600
http://www.suzukicycles.com/Products...s/Default.aspx
Kawasaki ZX-6R (Not showing preference, just the website is set up different)
SPECIFICATIONS
Engine: Four-stroke inline four-cylinder, DOHC, 16 valves
Displacement: 636cc
Starting: Electric
Bore x stroke: 68 x 43.8mm
Compression ratio: 12.9:1
Cooling: Liquid
Carburetion: Fuel injection with (4) 38mm throttle bodies
Ignition: Digital
Transmission: Six-speed with multi-disc back-torque limiting clutch
Frame: Twin spar aluminum
Rake / trail: 25 degrees / 4.2 in.
Front suspension: 41mm inverted cartridge fork with rebound and compression damping, plus spring preload adjustability and top-out springs
Rear suspension: Bottom-link UNI-TRAKĀ® with gas-charged shock, compression and rebound damping, spring preload adjustability and top-out spring
Wheel travel, front / rear: 4.7 / 5.3 in.
Front tire: 120/65ZR17
Rear tire: 180/55ZR17
Front brakes: Dual semi-floating 300mm petal discs with dual radial-mounted, four-piston calipers
Rear brake: Single 220mm petal disc with single-caliper piston
Overall length: 81.3 in.
Overall width: 28.1 in.
Overall height: 43.7 in.
Seat height: 32.3 in.
Dry weight: 362 lbs.
Fuel capacity: 4.5 gal.
Wheelbase: 54.7 in.
Colors: Lime Green / Flat Stoic Black, Metallic Raw Titanium / Flat Stoic Black, Candy Plasma Blue / Flat Stoic Black, Pearl Magma Red / Flat Stoic Black
Old May 16, 2005 | 04:56 PM
ZX12Rider's Avatar
This might help you compare http://www.powersportsnetwork.com/en....asp?compare=Y
Old May 17, 2005 | 03:23 AM
onewheel's Avatar
Default RE: why should I choose Kawasaki
numbers are great and all.. but it more about preference.. what you like
Me I took the kawi cause I liked price, I liked the look, and I know it can preform just as well as the others... plus you wont be like the other wannabees on the Honda's, and R6's Every one and there grandma.. has one.. be different buy a Kawi
Old May 17, 2005 | 03:24 PM
ZX12Rider's Avatar
Very true! First and foremost, it should be what you like the looks of, what is comfortable for you, pricing, etc....
What I love about mine - I have never seen a purple/black (depends on the lighting) Ninja around these parts. It is different but a real pain in the rear trying to find gear that will match (I wasn't too keen on all black for visibility concerns) But you make do with what you've got!
Old May 17, 2005 | 04:23 PM
Remo's Avatar
It's all down to preference, what feels comfortable to YOU!
Remember...the bike doesn't make the rider go fast, the rider makes the bike go fast!!
Old Jun 2, 2005 | 12:26 AM
ntence's Avatar
I feel that it is your personal choice, but I also feel that Kawasaki is a good sport bike because it is mostly a track ready bike. Wich I believe would be better for a first timer. It's sit up to ride hard, Ithink very rider friendly.
Old Jun 2, 2005 | 12:40 AM
PiKADanielB's Avatar
whatever is your STYLE and whatever you FEEL most comfortable on...the most reliable are honda and kawasaki...in my opinion....i say go kawasaki!
SXGT
Jun 1, 2008 10:03 PM
SKOOTR
Jan 7, 2008 01:54 PM
NicePaint
Joke section!
13
Nov 26, 2007 03:50 PM
jetblack
Jul 29, 2007 06:00 AM
Icantrideabike
Jul 14, 2006 09:35 AM
