06 zx6rr not starting
Old Mar 23, 2021 | 03:40 PM
Dan26's Avatar
Default 06 zx6rr not starting
Hi can anyone help plz bike turns over no spark checked immobiliser, sensors no f1 code im thinking ecu can it swap sraight in ?
Old Mar 24, 2021 | 05:10 PM
KevA's Avatar
Dan don't jump straight to the ECU it can be an expensive mistake as a side note you can swap out the ECU but you'll need at least the Red Master key which is coded to the ECU.
When you turn on the Ignition do you hear the Throttle Body actuator and the Fuel Pump cycle ?
Old Mar 24, 2021 | 07:25 PM
Dan26's Avatar
hey Kev the start up cycle sounds ok , long story short had bike two weeks was running fine then evey morning wouldn't start when it did high revs wasnt kicking in now nothing.left with mechanic he's checked all sensors and what haves.still nothing
Old Mar 24, 2021 | 08:04 PM
KevA's Avatar
Originally Posted by Dan26
hey Kev the start up cycle sounds OK , long story short had bike two weeks was running fine then every morning wouldn't start when it did high revs wasn't kicking in now nothing.left with mechanic he's checked all sensors and what haves.still nothing
Get your Mechanic to check Fuel pressure and carry out a flow test.
Attached a spec sheet.
File Type: pdf
Old Mar 29, 2021 | 09:13 PM
Some good info.
Moz
Jan 31, 2021 09:49 AM
David mx 250
Jul 19, 2015 02:42 AM
Mark Thompson
Jul 13, 2014 12:41 PM
Kawasaki636
Mar 26, 2007 06:18 AM
ewstevens3
Nov 2, 2006 05:32 AM
