KF Help & Suggestion Center Need help with KF? Ask. Have a suggestion to better KF? Tell us here.
Starting issue 2008 1600 Meanstreak
Old Dec 31, 2020 | 02:31 PM
Moz's Avatar
Moz
Default Starting issue 2008 1600 Meanstreak
Hi all, anyone able to help me out? Engine Turns over but won’t start. There’s spark at all 4 plugs, fuel being delivered at pots. Earth connections checked cleaned and tightened. Coil packs & leads resistance checked ok. Have you had this issue or have Any ideas? Thanks in advance
Old Jan 31, 2021 | 09:49 AM
KevA's Avatar
Might be late to the Party here but,
How many Miles has the Bike done ?
Are you able to carry out a Compression test accurately ?
If you have good Spark & Fuel that leaves compression as a likely suspect.
When you crank the Motor does the Fi light Flash ?
PLANB
Apr 23, 2022 07:29 PM
Fast.Matt
Nov 7, 2020 07:40 PM
TheRealGT
Feb 17, 2020 04:02 PM
chee1000
Jun 26, 2012 06:30 PM
scottfourwheeler
Apr 20, 2011 04:08 PM
