NEW KX 250 preignition noise
Old Jan 14, 2007 | 04:29 PM
Roger's Avatar
Default NEW KX 250 preignition noise
My KX250 is only a couple of weeks old and the first time I was able to open it up after breakin and there is a ping or knock in the top end at high RPMS in third, fourth and fifth gears. It sounds like an octane knock but I am running 93 octane mixed 32 to 1. Could the stock jet have me running too lean or would it be ignition timing. Looking for help, first questions to the dealer have not provided answers.
Old Mar 27, 2007 | 07:43 AM
2smokers's Avatar
Default RE: NEW KX 250 preignition noise
Whats your plug look like?
Old Mar 29, 2007 | 06:02 AM
KxKidd's Avatar
Its possible to be ignition timing...but i agree with 2smokers....whats the plug look like....if its too lean it will be lighter then tan to white......pinging is the fuel mixture detonating too early, much in same fashion as a diesel motor instead of using the spark plug....wont run quite right either......
Old Jun 9, 2007 | 03:46 AM
Mono's Avatar
It is absolutely important to use the right spark plug. the correct part is an NGK BR8ECMIX iridium plug. it is a short tower resistor plug that has a very high flame face.
If the incorrect plug is used the radio noise will cause the CDI box to malfunction. On your bike the CDI box controllsignition curve and also the powervalves. the noise you hear are the sub valves slapping open and closed under high engine load with the improper plug. While many plugs make the bike run, there is only one correct plug. The BR8ECMIX was designed along with and specifically for the '05 KX 250.
Old Jul 10, 2007 | 10:58 PM
raggi's Avatar
You should run it on 95 oct. and never mix the 2 stroke oil in the tank allway´s in a gas bottle ( understand) 1-32? I did it allways 1-20 and never had problems!! and never let the 2 stroke bikes run in nutreal allways in high rpm... also what Mono said is correct....
Old Apr 19, 2008 | 12:31 PM
HOEVE1's Avatar
ORIGINAL: Mono
Hey mono I have an 04 kx250 and am having a hard time keeping plugs in it, I have lowred the main jet 2 sizes from stock and raised the needle and still foul plugs,Im using the BR9ES NGK plug, Could this be my problem? Within 5-10 minutes of riding they foul, I have had this bike 2 yrs bought it new left over and have changed 20+ plugs in this thing, I cant find anyone to help me out with this, The dealer charged me 75 dollars to change the plug startedand ran it for a few minutes and said its fixed, I want to set this bike on fire, lol
Old Apr 19, 2008 | 02:11 PM
OMalley912's Avatar
A notorious problem. My friends new04 kx250 had the idenical problems. Tried everything, air screw, jetting, pipes, slider etc. Although he wasn't banging the power band as much as he should it was nothing but a headache. Just a bad carb design. Finally got tired of it and went to 4-stroke.
codyw2012
Sep 8, 2012 12:59 AM
frankb
Mar 27, 2010 04:00 PM
kawasuzi
Ninja 250R
24
Jun 17, 2008 07:29 PM
94Ninja250
Apr 17, 2008 12:47 PM
barrons03
Feb 22, 2007 04:28 AM
