04 kxf250 starting problems...
Old Oct 13, 2014 | 06:25 PM
dubownerbilco's Avatar
Angry 04 kxf250 starting problems...
i am new to the forums so hello
right so i have done lots of searching around the internet and found lots of people with similar problems but i never seem to find a solution so i am looking for some help catered towards me and my bike!
some background info on the bike:
purchased a few months ago from a friend of a friend who said it was always hard to start but he just bump started it constantly and it never bothered him, and admittedly it did ride ok when i got it, although it did backfire ALOT on overrun! and he never maintained it so my first job was to pull it apart and inspect everything. found the valves were wayyyy out of spec so i attempted to re shim them but they were no where near. so i ended up pulling the top end apart and found the valves were completely frigged... so i rebuilt the top end, also fitted a new timing chain as bumping it had stretched it by half a tooth! and then replaced all gaskets etc it also had a new plug and filter etc etc
the bike also has an Athena 290 big bore kit fitted by a previous owner
the problem:
bike will start on choke from cold after just 3-4 kicks and will fun and ride fine, although still popping alot when revved or just on over run. HOWEVER if you stall the bike or just cut it off and try to restart it when fully warmed up, well you will get bored and go home before you get it running again!
i am rapidly falling out of love with this bike because of this problem please help!
i have no problems doing any work on the bike but i would like a list of what to check and in what order they should be carried out
Old Oct 20, 2014 | 05:56 PM
well for anyone who actually cares, the problem is sorted
turns out the carb slider was upside down which held the throttle open more than the tps thought it was! flipped it the right was up and bobs your uncle!
safe to say i wont be visiting this forum again, adios!
deeppowder
KX250 & KX250F
Oct 16, 2012 01:52 AM
NOLA500Ninja
Ninja 500R
Feb 12, 2007 09:56 AM
remster
Jan 2, 2007 06:52 AM
Joe00zx
Oct 26, 2006 08:57 PM
schnebelen
Jul 6, 2006 05:38 AM
