KLX 300R Hard Starting when hot
Old May 28, 2012 | 10:26 PM
rbutler's Avatar
Default KLX 300R Hard Starting when hot
Hi, I recently rebuilt the top end of my sons KLX 300r (new valves,piston, gaskets,valve shims) everything is in time and the valves are shimmed in spec. the bike starts fine cold and runs great. the problem is when he shuts the bike down he cant it started for about 15-20 min. did i miss anything we didnt touch the carb (stock). i tried the idle mixture screw a couple of different positions,same thing happens. if anybody has any other ideas or has had the same problem i would appreciate some help. Thanks Bob Butler
Old May 7, 2014 | 04:49 AM
Bernie's Avatar
probably the pick up clearance too big...
take the left cover of, the pick up is in there... kinda hard to measure..what you do..with screwdriver..bend it down a bit.. less then 0.5mm..
cover back on..turn the engine over.. you'll hear if the rotor scrapes.. then it was too much, if no noise.. its fine..
pullin_gs
Mar 22, 2022 05:48 AM
tonloc
Jun 14, 2015 05:22 PM
snipepod
Jul 1, 2011 02:40 PM
Snal
KLX300R
Apr 27, 2007 05:35 PM
kwninja88
Aug 22, 2006 12:59 PM
