I just got a new 05 klx 110 and it doesn't have spark. The previous owner and me combined have know replaced absolutely everything that is in the ignition system. Flywheel, stator, ignition coil, rectifier, kills witch, spark plug/ boot, CDI, Wiring harness. After all that still no spark! Now I have two questions. What color wires go to which terminal on the Ignition coil. Then I how do I ground the nuetral saftey switch?
These are the nuetral saftey switch wires. Im supposed to ground the plain green wire correct?
I had the yellow and black going to the green terminal and the black going black terminal
