2009 Klx250sf no spark
Old Apr 17, 2025 | 05:04 AM
KLX250SF2009's Avatar
Default 2009 Klx250sf no spark
I have no spark found a green wire with white stipe broken that rubber against the rectifier repaired the wire but still no spark please help
Old Apr 19, 2025 | 02:41 PM
GBAUTO's Avatar
Based on the schematic I have, that is one of the leads from the crankshaft sensor.
See if this helps any:
https://www.dropbox.com/scl/fo/fvvbm...pvz70p6yauu51o
Old Apr 21, 2025 | 03:32 PM
Thank you I already have that service manual I have another complete stator rectifier and crankshaft positioning sensor. I swapped it out and it’s still the same thing. I also compared the resistance to both and they’re pretty much on the money. It’s kind of thrown me for a loop now because if you hook up all the grounds to where they should be cleaned everything’s making good contact when you hook up the negative side of the battery like normal tail light headlight comes on, but it loses power to the orange wire that connects to the black with the white striped wire for the coil and if you take the ground off the battery you’ll get power back to the coil to the orange wire I pulled the wire harness last night opened it up. I don’t see anything that was cut rubbed of that sword pulled out the ignition check that everything’s good kick stand safety switch bypass neutral safety switch good Killswitch good the safety switch for the clutch bypass. There’s anything else you can think of would be greatly appreciated. Thanks.
Old Apr 21, 2025 | 05:24 PM
I do have a new coil showing up today so we’ll see what happens. I don’t think it’s the coil, but I’ve been wrong before.
KLX250SF2009
Apr 16, 2025 04:55 PM
LemonRX
Aug 16, 2017 02:07 AM
7layercooki
Mar 1, 2016 01:17 PM
chadwalsh7
Jul 14, 2014 11:52 AM
Mott Power
May 12, 2009 11:19 AM
