You'll kill me for this....
Old Apr 5, 2014 | 01:55 PM
Originally Posted by Richard Avatar
I don't ride mine off road, at least not in any grimy conditions. But it'd seem to be simple enough to fab something up to keep dirt from going down the spark plug access area and not have to worry about crap falling down in there whenever you pull the plug?
Even some sort of sponge material crammed around that long plug wire cap. Something that engine heat won't destroy.
At least in a garage/shop environment, you can start backing the plug out but only about half way or so. Then take high a high pressure compressed air nozzle and blow the crap out of the area all around the plug. I've never had anything fall into the plug hold using this method. I haven't had to change a plug in the field since the days I ran 2-strokes, so the compressed air method always works for me.
Old Apr 5, 2014 | 01:57 PM
Yeah and next time clean the area before you work on it, come on, that bike maintenance 101 man! LOL
Old Apr 5, 2014 | 09:17 PM
Oreganic's Avatar
Fair enough deej - lesson learned. I haven't been around here very long but I take it you're the bawse of one clean machine!
I like the idea of taking the plug halfway out and blasting the area while its dry. I think that would have saved me the stress.
I changed the oil/filter last night as well and saw nothing out of the ordinary... except my eternal battle fidgeting with the filter spring for 10 minutes.
Old Apr 5, 2014 | 09:30 PM
MaximusPrime's Avatar
After a field plug change, where I was worried about what happened to you, I now carry a piece of clear hose to blow out the area.
As to the stupid filter spring...Open the end of the spring so it stays in place or put a bit of grease on the end and stick it to the filter and then put the filter in.
Old Apr 6, 2014 | 05:27 PM
Oreganic's Avatar
Good stuff, thanks. I eventually used a glob of grease and a slightly more aggressive tilt to the bike.
Tubing is now included in my kit. I don't feel like spark plug changes are very common on these bikes - but I could be wrong. I'm used to frequent checks/changes with snowmobiles and thus far I've not had the inclination to check the plugs outside of yearly maintenance/winterizing. Maybe once I DJ I'll be checking for lean/rich characteristics...?
IGonzoI
Aug 13, 2009 12:13 AM
shon
Aug 15, 2006 04:44 AM
KlyntZx6r
Jul 17, 2006 11:54 PM
shon
Nov 17, 2005 11:20 PM
Wannabe250
Oct 11, 2005 01:42 AM
