Wrestling the carb in and out of the frame
Old Apr 29, 2017 | 03:34 AM
ronopolis's Avatar
Question Wrestling the carb in and out of the frame
I'm jetting my carb on my '13 for the first time. I've take the carb in/out of my kdx220 2-stroke a few times, and it is relatively simple. On my KLX250s, maybe it is just me but I struggled getting the carb out of the frame. I had to push/squish the air-box pipe out of the way. Wiggle prod curse push wiggle... I did get the carb out, but before I put it back in, are there any tips/tricks I'm missing? Or is it just really tight and a struggle?
Old Apr 29, 2017 | 04:12 AM
Loosen the boot clamps, unbolt the bracket that holds the throttle cables. Rotate carb while leaving it in the boots. This should give you room to pull the jets with out wrestling the carb all the way out.
Old Apr 29, 2017 | 10:21 AM
s10gto's Avatar
Take the header pipe off also. Then as posted above just rotate.
Old Apr 29, 2017 | 11:26 AM
dpippin's Avatar
Here's some info on removing the carburetor
Carburetor Removal
Doug
corkman
Jun 9, 2013 10:03 PM
Rooookie
Aug 14, 2008 11:52 PM
stjoetalon
Apr 17, 2007 08:14 PM
ZX_9r
Jan 7, 2006 04:23 PM
