Winter Storage?
Old Oct 28, 2009 | 04:16 PM
hercrigger's Avatar
Default Winter Storage?
Well, as much as it pains me to do so, I think it's time to put the bike away for the winter. Since this is my first bike and first time doing this, what do all of you guys do in terms of getting your bikes ready for long term storage? I'm planning on draining the carb and gas tank, dropping the tire pressures and pulling the battery, bringing it inside and putting it on a tender. It's got fresh oil in it now so that should be fine.
Anything else???
Old Oct 28, 2009 | 04:51 PM
jxg's Avatar
jxg
ride it! I plan on starting mine at least once a week, put on all the winter cloths, and at least go up the road. and if the road is clear enough to get to the trail, romp on the trail a bit. Of course i am in the Northeast, not ON, so I guess I have that option...
Old Oct 28, 2009 | 05:44 PM
Beardoge's Avatar
Well let's see, I turn the key off in the fall, push it in the back corner of the barn.
Springtime: I push it out of the barn and turn the key on.
Old Oct 28, 2009 | 06:16 PM
roadglider's Avatar
If it gets cold and it is humid there you might be better off filling the gas tank with quality 100% gasoline and then putting Stabil in with the gas. Fire it up to run the stabilized fuel through the carb and leave the tank and carb full with the stabilized fuel. Remove the battery and put it on a tender and put the bike up on a stand so that the tires are not touching the ground no need to let the air out. Wash it and spray it down with WD-40 wipe it off and lube the chain and your good to go. As jxg said it never hurts to start it up once in awhile. P.S. These things can be hard starting when it's cold out. Everybody has their own routine, I just lay mine over on the right side until gas runs out the over flow, pull out the choke and then hit the majic button. It starts every time.
Old Oct 28, 2009 | 08:30 PM
lcpl0331's Avatar
Roadglider nailed it. Follow that and your good to go. In the spring I drain the gas and put in fresh stuff then use the winter gas for the lawnmower.
Old Oct 28, 2009 | 11:35 PM
truckinwagen's Avatar
stabil in the gas, and get some fogging oil.
follow the directions on the side of the can.
Old Oct 29, 2009 | 12:12 AM
jsac's Avatar
Anything else???
leave the gas tank full. treat it with stabilizer. the tank is metal, if you drain it, when temps swing you will get condensation in it and rust may form.
Old Oct 29, 2009 | 12:47 AM
95451's Avatar
+1 Turn Fuel Off
Run The Bike Tell She Sleeps
Add Two Blankets.
And Tuck Her In
Old Oct 29, 2009 | 04:03 AM
hercrigger's Avatar
too easy guys! thanks again!
Old Oct 29, 2009 | 04:30 PM
Dropping the tire pressure? I would say keep it topped off to avoid tire checking.
