Where to mount plate? where's legal??
Old Nov 23, 2011 | 02:28 PM
Ranger Ron's Avatar
On my 2006 the plate broke off, too. The bracket didn't break off, but the plate itself broke off the bracket. I added some reinforcements behind the plate. You can see the extra attaching bolts in the picture. No problems since.
Ron
Old Nov 23, 2011 | 09:05 PM
turnsleft's Avatar
Originally Posted by wildcard
I would be careful about beefing up the plate holder like that. in the event of a crash a big strong piece of steel like that bolted to the subframe may cause bad things to happen.
It is aluminum, I couldn't get the 1/2" steel to bend in my press.
Old Nov 23, 2011 | 11:11 PM
BleednGreen68's Avatar
I would run it like you have it till you get pulled over. All they will do is probably give you a ticket and tell you to put it in the right spot. Take a pic of it and take it to your court date and they will more than likely wipe the ticket. I did that on my 05 636r ninja. My bracket broke so I put it way under the fender. A state trooper got me cause he thought I was one of those stunters that they have probs with here on the interstates in KC. They hide their plates so its harder for the cops to see them. I told him I had a new bracket coming and this was just temporary. Told me to take a pic of it when I put it in the right spot and they will wipe the ticket. I bought a bracket off ebay that actually mounts it to the rear axle. The plate was sideways now and never had a bit of trouble. Didnt even have a tag light on it. Just depends on yer states laws AND if the cop that stops you is in a good mood or not.
Old Nov 24, 2011 | 02:36 AM
09'Kawi250s's Avatar
ya thats what im gonna do. i dont ride it much on the road in the winter anyways. My first plate broke off on a trail somewhere and i got a ticket but it was a free fix it ticket
Old Nov 24, 2011 | 11:12 AM
I broke a few plates I made when I tried to solid mount my plate - 650 vibrates the fender pretty bad.
I then got smart and made it like the old trials bikes and all - I cut a flap from a fiber reinforced piece of rubber (aka truck mud flap chunk) cut it to fit the plate and have a tab for mounting on the fender, drilled two holes in the back tip of my fender and hung it there with a couple of aluminum pan head screws - swingin' in the breeze. No problems now. Of course in Ohio there is apparently no issue with plate lighting in spite of the law that it has to be lit, because mine doesn't have any light and I've not been pulled over. Maybe I'm just lucky. But if I ever get flak I'll buy a couple LED plate light/bolts off ebay afor a few bucks nd fit them.
I like the inside the number plate mount, which faces backward filling the law. No worse than those axle mounts choppers use. If you have to, get the LED plate light/bolts off ebay.
Old Nov 24, 2011 | 03:33 PM
up on the fender..
Old Nov 29, 2011 | 11:26 PM
I guess Kansas tags are trail rated hahaha.
MSR 05 6R
Jan 23, 2009 01:32 PM
jrc0283
Nov 21, 2008 12:45 AM
ktn
Nov 8, 2007 03:11 PM
mdc160
Ninja ZX-10R
13
Sep 27, 2007 01:06 AM
bmoore
Aug 31, 2005 02:42 AM
