Web Cams Camshafts?
Old Feb 5, 2017 | 04:10 AM
Originally Posted by GBAUTO
The carb's biggest impact is throttle response-I suppose that it's possible to get better results from the oe CVK but it was a problem for me when trying to navigate some of the more challenging offroad sections.
I also did some clean up and matching of the ports when I had it apart. My professional background is in hi performance automotive so I've seen quite a few heads. Based on that, my opinion of the port design of the head is a major impediment. The exhaust port is a compromise because of the elbow it has to make to clear the frame downtube. I just don't think that any potential gain is going to warrant anything beyond what you're going to get for the money. I did it because I was already in there and had the equipment to do it. sorta like..You can't make a silk purse out of a sow's ear..
Yeah, I like that little additional snap of throttle response from the pumper carb on a bike that isn't exactly a ball of fire in the power department. I also notice a quicker trip to redline from about 7K rpm or so. I had four KLR600/650's over time with the CV carb, and they always worked...just like the pumper better.
Old Feb 5, 2017 | 12:27 PM
Reminds me of the Gordon Jennings article on hopping up the SR500 written back in 1979. He found the intake bend to be so tight that it was a waste of time to go to a 38mm carburetor over a 36. One boost was filling the bottom of the intake port a bit, making a D port to help eliminate the slow and turbulent flow on the bottom going in the cylinder. It was interesting. The solution, that some actually would do, was to weld up a bunch of the head to get the port cut with a lesser curve for a straighter shot into the cylinder. Of course those doing that were flat trackers and some others since it could be a competitive engine on the flat track back then. Lots of money though. For my own SR it was just a carb and 33"x1.625 head pipe. The most you could get for the lowest cost.
Old Feb 5, 2017 | 03:03 PM
atleastbehandy's Avatar
Originally Posted by scubiedoo22
behandy, thank you for that tid bit of info. that's something i overlooked and didnt even think about. do you know where can i get the shim kit?
​​​​​kit is $80 here:
https://procycle.us/bikepages/klx250s.html
Bike bandit has it too I think.
Old Oct 14, 2017 | 12:13 AM
Brewster's Avatar
I was just helping a guy with his KLX300. He's at least the 3rd owner. We were trying to put the cams back in, piston at TDC and slash marks on the cams parallel to of head. But, in that position, the lobes on both cams were horizontal, intake pointed back and exhaust pointed forward. As I recall from a few years ago, they should be pointing slightly up. While handling one of the cams, I noticed that Web and 307 were inscribed on it. OK, Webcams. I don't see a 307 cam on Webcams site. Any body here familiar with them and should the lobes be horizontal at TDC????
Thanks
Ride on
Brewster
Old Oct 14, 2017 | 01:41 AM
GBAUTO's Avatar
Just a visual exercise-TDC @ powerstroke so in ~ 180 deg. of crank rotation the exhaust starts to open. That should be 90 deg of cam rotation-so the nose of the lobe should be at a right angle to the valve centerline.
Old Oct 14, 2017 | 03:40 AM
Brewster's Avatar
Bike owner found out that the cam is a discontinued Grind #293.
Ride on
Brewster
Old Oct 14, 2017 | 12:48 PM
snappster's Avatar
Looking at my service manual I see exhaust opens at 60 degrees BBDC which means after about 120 degrees of power stroke the exhaust valves start opening. That is 60 degrees of cam rotation. I would say a nearly horizontal exh cam lobe center at TDC is pretty close to correct.
Old Oct 16, 2017 | 02:12 AM
queen of spades's Avatar
Does the KLX300 head have larger ports to better handle a non-oem cam grind?
Old Oct 16, 2017 | 03:34 AM
Brewster's Avatar
I don't know about the port sizes, but the cam referenced above is not a high rpm cam. It's for a stronger mid range.
Ride on
Brewster
grahamgower
Jul 26, 2013 08:05 AM
PTECH
Sep 26, 2011 12:34 AM
turbomaniac
Mar 24, 2011 07:20 AM
Marty
Feb 13, 2008 04:46 PM
Team FTB
Jan 14, 2007 08:53 PM
