WARNING ON HELP BRAND PLUGS
Old Jun 8, 2006 | 03:49 AM
Richt's Avatar
Default WARNING ON HELP BRAND PLUGS
Just letting everyone now that i used the help plugs when elimanating the air pumpback in march.When i went to install the new jet today i noticed that all three plugs i used were dry rotten and cracked all the way through.I had to cut short hoses and silicone the ends off.
[IMG]local://upfiles/1719/BAB5A59C00494DDD818B11B18169180B.jpg[/IMG]
Old Jun 8, 2006 | 04:51 AM
konacoiler's Avatar
Default RE: WARNING ON HELP BRAND PLUGS
Thanks for the heads up. I just used those very same caps last night. I was concerned about heat being an issue when I put them on.
Old Jul 1, 2006 | 11:44 PM
mrphone's Avatar
I used the Help brand plugs too and they rotted on me. Has anyone found better plugs? I just went to Lowe's and tried the hardware section and the guy told me to try Bed Bath and Beyond?!?! I read that Todd bought some at Lowes - anyone know which department they might be in? I looked over the whole store with no luck...
Old Jul 2, 2006 | 06:13 AM
incabiker's Avatar
SHAT!! I used these on both my VTX and my KLX to cap off the vaccum system. Damnit. So What is the solution to this, to use silicone to cover it up?
Old Jul 2, 2006 | 08:58 AM
BigRig18Wheeler's Avatar
I used to have the same problem on an old 4 wheeler that I had..... Anyway, the Holley brand vacuum caps are a lot thicker and lasted a lot longer than the help ones....
http://www.holley.com/26-105.asp
Old Jul 3, 2006 | 05:47 AM
incabiker's Avatar
What happens if we take the wires that originally came off with the Smog sysytem and cut them short, put silicone on the end of them so that no air gets out. This way we have a good rubber compound that won't dry rot, at least I would hope they would'nt coming from Kawasaki, and problem solved
Old Jul 3, 2006 | 06:26 AM
klxcrazy's Avatar
i got an assortment of plugs at napa. hope mine arent doing the same thing.
Old Jul 3, 2006 | 07:07 AM
motoguy128's Avatar
ORIGINAL: incabiker
That's all I did to most of mine.... except that I stuffed a very small screw or a brass pipe plug in the end first.
seizetheday4eva
Aug 14, 2012 04:25 AM
zx6fr
Dec 23, 2008 02:03 PM
cleverwon
Jun 23, 2008 12:43 AM
SlayerX
Ninja 650R
May 5, 2008 06:41 AM
Motopsychoz
Jun 3, 2007 11:15 PM
