Vibration
I took my bike into the stealership last week to have the gas tank recall work done and now my bike vibrates in the gas tank area. However, when I put my legs against the shrouds, it seems to stop or muffle the noise. It does not happen at all speeds or gears. Not sure if the gas tank is causing the noise, shrouds hitting the gas tank or something else? I have not had a chance to track down the problem yet and wanted to know if anyone had any suggestions on where I might start? Thanks
It could be many things, but you'll need to pull the tank yourself and inspect the tank and frame interface. It could be something simple like one of the rubber bumpers falling out or not being installed correctly to some other component hitting the gas tank. You always go back to the last thing done, and since the bike was in the shop for that recall, I'd inspect everything in the area of the bike where that work was done.
I hope that it is an easy fix because I seem to spend more time working on the bike, than riding it. Also, it is very sad that the dealership always seems to create problems for me when I bring my bike in and then they want to charge me for their mistakes.
I'd also make sure the front of the seat is secured to the gas tank. When I put my new seat on the padding was a little less in the front and could hear it vibrating. I had to bang the clasp down a bit to make it a more snug fit.
I tried pulling up on the front part of the seat when it started to vibrate, but it did not seem to help. When I push on the right radiator shroud the noise seemed to stop. I am not sure if it is the shroud vibrating against the tank, radiator guards or gas tank touching part of the frame. However, I am sure it can be fixed, but I might have to take half the bike apart and slowly put it back together piece by piece. I just didn't want to kill my whole weekend chasing this ghost, but it is really annoying and I am tired of my bike being in pieces. I just want to ride!!!!
I've had the same happen after I've put things back together. Usually if you loosen the bolts that hold the shrouds on and then retighten it seems to quiet things down. You may need to put presure one way or another on the shroud with the bolt partially in to make it tighten up against the tank or other offending piece.
