vapor - dashlight connections
Old Jun 5, 2008 | 02:35 PM
nosneb69's Avatar
Default RE: vapor - dashlight connections
cheers for the pics, I am still trying to work out how to put lots of pics in one thread...? duh! anyhow I notices with your three standard tach cables you have only used the black and the black yellow. black yellow is the negative and the black in the positive for the vapor.....the brown in just capped off.....?
many thanks again.
Old Jun 5, 2008 | 07:31 PM
nosneb69's Avatar
so i have it hooked up just the way you have Gany but my tach seems to be reading about 1000 too much...?! What the F&*K... is that all about?
Old Jun 5, 2008 | 10:25 PM
Gany's Avatar
Dont know mate, mine seems to work fine that way. Maverick connected his as per the instructions, perhaps try that?
Old Jun 6, 2008 | 12:39 AM
nosneb69's Avatar
man I tell ya, these things just seem to get me all twisted up....so I got the tach working to as near as possible and I was just wondering what wheel setting size you used....? I put the default - XXX I used the method in the book - xxx it seems to be under reading...? I reset the sensor - xxxx no joy just a question..?
I dont know but I think I have a gremlin in this bike...I am not sure if you read my other thread but my CDI unit went out on me just as I got it.....since then little troubles have been foloowing me!!!
Old Jun 6, 2008 | 05:58 AM
Gany's Avatar
My wheel setting is for motard rims so will not be any good to you. Set the diameter, go for a ride, if you have a GPS then check the speed against that. If its wrong, change the diameter till you get it right. Even if I didnt have the motard wheels on the measurement will most likely differ depending on what tyres you have etc. The only way to get it right for your bike is to set it with your bike. Good luck.
Old Jun 6, 2008 | 02:44 PM
nosneb69's Avatar
good point, cheers for the pointers. I will have to go along side another car or something and check it that way.
anyhow - I will be out riding this weekend so have a good one.
handymandbq
KX85
Apr 25, 2015 06:04 PM
Richard Avatar
Mar 14, 2014 02:44 AM
jeffzx9
Jul 5, 2011 05:39 PM
OldDualSporter
Jan 24, 2006 07:00 PM
kaw98zx6r
Aug 18, 2005 05:55 AM
