Valve clearance check
Old Dec 1, 2018 | 11:18 PM
583KLX's Avatar
Default Valve clearance check
My bike isn't starting and I have a good battery. 11k on it I don't think po did a check. With my OLD when it wouldn't start it ended up being the valves.
Anyways I've been looking the innerwebs trying to find the specs for the valve clearance. Bike is a
2012 KLX250s.
Any help would be appreciated.
thanks
Old Dec 1, 2018 | 11:53 PM
Verwah's Avatar
Here ya go.
Intake: 0.10mm - 0.19mm
Exhaust: 0.15 mm - 0.24 mm.
Your bike doesn't have a ton of miles, so make sure you check stuff like spark and fuel first.
Old Dec 2, 2018 | 01:36 AM
583KLX's Avatar
Thanks. Fuels good, when I have it off I 'll check the plug. Didn't think of that.
Old Dec 2, 2018 | 02:19 AM
durielk's Avatar
It's probably not the valves... these bike are the hardest things to start that I ever owned. You just need to get in the right mindset, or fix your carb.
Old Dec 2, 2018 | 10:32 PM
At least remove the spring from the compression release, it is unnecessary. If you haven't done it, jet the carb. It is too lean everywhere. If you use Dyno Jet check out KLXter's set up. If you use Kawasaki stuff look in the link in my signature for the set up riders have used for years. It is from D. Pippin's web site. I did the Kaw stuff myself along with a Dial-A-Jet. Works fine and I have fired it up in 3 degree F temperatures, no problems.
Old Dec 3, 2018 | 12:15 AM
583KLX's Avatar
Thanks Im definitely looking at that. I've been searching off and on the past few months what kind of set up I should do with a FM4 Q4 muffler at 4000ft.
mid-life crisis
Mar 22, 2015 07:06 PM
daren1093251
Apr 14, 2014 11:40 PM
Arctra
Apr 21, 2012 03:43 AM
KDXmike
Jun 21, 2008 01:19 PM
Ginsu4u
KLX125 & KLX125L
Sep 10, 2006 09:49 AM
