Valve Adjustment
Old Jul 14, 2012 | 01:55 AM
WHIP-N-DIP's Avatar
Default Valve Adjustment
So it's about that time for my first valve adjustment... theyre starting to rattle a bit and I've never adjusted valves on any bike before... thought i'd ask here for some instructions considering i don't have a copy of the service manual for my 2009. Any help will be appreciated! thanks again guys
edit: found a copy of the service manual on here, any advice helps though!
Old Jul 14, 2012 | 02:17 AM
drm's Avatar
drm
This may seem silly to say but there was a recent thread here if you search for valve in the title thread...
Old Jul 14, 2012 | 02:25 AM
JoelThailand's Avatar
This valve/shim adjustment thread has got everything you ever need to know....
https://www.kawasakiforums.com/forum...acement-35136/
Old Jul 14, 2012 | 02:32 AM
On the rattle, they usually get tighter not looser...don't they?
Old Jul 14, 2012 | 02:49 AM
stephenmarklay's Avatar
I am with TNC. You may need it but I think things like lower power and or harder starting or just time is a good reason to do them.
Old Jul 14, 2012 | 03:43 AM
wildcard's Avatar
as far as i know yes.
CCT ?
Old Jul 14, 2012 | 05:25 AM
go cytocis's Avatar
Rattle you descrbe may be cam chain...
Old Jul 14, 2012 | 02:32 PM
djchan's Avatar
Ya, loose valves are happy valves. Check the rattle's rpm and if it's in the vicinity of 5500 rpm your probably talking cam chain noise.
Old Jul 14, 2012 | 03:06 PM
Blackheart58's Avatar
Amen.
Old Jul 14, 2012 | 03:30 PM
WHIP-N-DIP's Avatar
i'll give that a shot then... how do I adjust my cam chain*** ;]
