Two silly electrical questions
Old Oct 16, 2008 | 04:00 PM
neilaction's Avatar
A relay has only one function here.
It reduces the current load on the "switch", if there is one.
A relay allows a relatively low current/power circuit to control higher current/power circuit.
If you are not intending the socket to be switched, forget the relay.
Fuse it straight to the battery.
If you want the socket to be switched, and the current draw will be higher than the ignition switch and /or existing wiring can handle, use a relay.
Coil side of the relay to the ignition switch circuit and the contacts straight to the battery.
Am I making sense here?
Old Oct 16, 2008 | 04:08 PM
Originally Posted by deej
One thing that is sort of related, don't use the red kill switch to shut off the bike, like they teach you in the MSF class, everyone that I know that uses that instead of turning off the key only, has left thier lights on and ended up with a dead battery. I use the key only.
I realize this is off topic for this thread, but I'm surprised they teach to only use the key instead of the kill switch. I always use the kill switch. Why? Because in an emergency situation where you NEED to shut down the bike immediately, reaching for the kill switch should be natural and almost reflexive. If you shut your bike down all the time with the kill switch, the repetition will teach the motion over and over making it natural and automatic and you'll be able to do it without having to even think about it and those precious seconds may make all the difference if you need to kill the engine in an emergency.
So if the throttle sticks open or something and you need to quickly shut the bike down, and too many things are happening around you for you to have time to think, killing the engine is an automatic reflex, just a thumb movement away. On the other hand, it's not really possible to take your hand off the bar to turn the key off in a situation like that.
Sorry for the thread jack.
Old Oct 16, 2008 | 04:20 PM
Actually Brian if you read my post again, they do indeed teach students to use the red kill switch, And in an emergency I would use that red switch, but for every day shut downs I use the key. That's just me, but like I said everyone I know that routinely uses the red switch has ended up leaving the switch on and ended up with a dead battery. To each their own I guess. But the first time I ended up with a dead battery using the red switch when I first got the bike, was the last time.
Old Oct 16, 2008 | 04:42 PM
Ah, ok, my mistake - parsing error on my part.
Old Oct 17, 2008 | 02:49 PM
tremor38's Avatar
I wired my ACC plug directly to the battery through an inline fuse. So far, I have not had any issues with leaving accessories plugged-in or left on in over 2-1/2 years, but to each is own.
One thing though. 'Jumping' the bike through an accessory plug was mentioned earlier in this thread. I wouldn't recommend that unless you proceed very carefully...as in letting the batt charge for a good while before trying to crank it over. Otherwise, you can easily blow the fuse on your acc outlet by cranking it while the batt is still real low. Whenever possible, go directly between the batteries with something much more 'beefy.'
Old Oct 17, 2008 | 03:59 PM
Jumping the bikes is fine, I tried it a couple of times, and as long as you just connect the jumper and wait like 3 minutes, the other bike will crank right up. Its all good.
Old Oct 18, 2008 | 01:28 AM
tremor38's Avatar
Yeah, just wanted to cover the territory where someone might get in a hurry and try to crank aggressively with a real low batt before allowing it to charge for a bit. It wouldn't be the end of the world if you blew a fuse, just an inconvenience or mild PITA.
Whenever availble, I'll stick with real jumper cables; preferably rated at a min of 30A continuous, but hey you gotta use what's available. I think I mentioned 'proceed carefully' in the original post, which appears to be what you did.
Buddy Lee
Apr 1, 2008 06:47 PM
JETHRO980
Feb 20, 2007 11:36 PM
EMS_0525
Dec 27, 2006 03:06 AM
gotrice
Jan 26, 2006 06:50 PM
Birchmanjr13
Jan 13, 2006 01:56 AM
