Turn Off Head Light?
Old May 25, 2012 | 01:44 PM
Websurfing101's Avatar
Default Turn Off Head Light?
Has anyone made a custom switch or device to turn off the front head light? I am riding in some questionable areas and do not want to attract attention to myself.
Old May 25, 2012 | 02:01 PM
jeffzx9's Avatar
My old Husky has an inline push-pull switch on the headlight/number plate cowl. Should be easy enough to wire-in. Find your wires and put a toggle inline.
Old May 25, 2012 | 02:09 PM
There are some good older threads on this you may want to search for. I simply cut the headlight ground wire and installed simple SPST toggle switch.
Old May 25, 2012 | 02:37 PM
"Questionable areas"?...are you tending that marijuana crop in the dark again?
Yeah, I put a headlight switch on my KLX just to cut down on voltage draw when riding off road since our bikes don't come with a kick starter. I used the ground wire method like IDRIDR. Someone here mentioned that there would still be some current draw with this method, but I hooked up my multimeter in a couple of tests and didn't detect any draw whatsoever with the main headlight ground wire in a switch. I did the same thing with my last KLR650. Make sure you run a switch worthy of the current draw in that circuit when the switch is on. I was going to run the taillight in this loop, but I left it in operation as it seems to keep me from being run over by KTMs and other race bikes when riding in a group...LOL!
Old May 25, 2012 | 02:49 PM
The small current draw it seems is through the high beam indicator lamp when the new switch in ground line is open (off). I think this happens only when the dimmer is in high or low position (don't recall). TNC - you run a vapor computer, don't you? Did you include the dash with indicator lights? If not, you wouldn't notice the draw.
Old May 25, 2012 | 03:04 PM
Ah, that must be it then. Yeah, I have the Vapor and no high beam indicator.
Old May 25, 2012 | 03:05 PM
When I was riding yesterday evening, I literally stopped deer in my head lights. Got me thinking, that I don't want Johnny Law or a Rancher with a new Browning to do the same thing.
turtle
Nov 5, 2006 06:35 AM
aszrael1266
Oct 23, 2006 08:16 AM
kaggriff
Jul 4, 2006 03:14 AM
Ratkiller
Apr 20, 2006 01:26 AM
sdrawkcabssa
Aug 6, 2005 04:04 AM
