Tube Noob
Old Jan 29, 2010 | 03:56 AM
maninthesea's Avatar
Default Tube Noob
So I have my tire selection prettymuch down and thought I would go on to the easy part-getting a couple heavy duty tubes at the same time.
I was pleased to find out there are Ultra Heavy Duty Tubes. But then when I started trying to sellect a tube I noticed that they tubes say they will fit such and such size tires. It looks like the HD and UltraHD tubes have a very narrow band of tires they will fit.
I have an 80/90 on the front with a lot of miles left on it and want to order a 90/90 as a replacement. I want to buy a tube that fits both. All the Heavy and Ultra Heavy Duty tubes I see only are listed to fit one or the other.
Can I get one tube that will cover both? If I get the 90/90 tube will it wrinkle and pinch in the 80/90 caseing? Or will the 80/90 tube be over stressed to fill the 90/90 cavity?
Same question more or less for 120/80 and 120/90 18" tube for the rear.
Thanks in advance
Jim
Old Jan 29, 2010 | 04:09 AM
punkenduro09's Avatar
i have a 120 that i have put in a 130, and a 110. as long as it is close, it will fit.
Old Jan 29, 2010 | 12:04 PM
if I want to have one tube and make it work on both tires should I get the one that fits the bigger one or the smaller one. Or is there not much differnce
Old Jan 29, 2010 | 02:18 PM
I installed the Kenda Heavy Duty tubes a couple of years ago, they are the best.
Old Jan 29, 2010 | 05:36 PM
i would go bigger.
Old Jan 29, 2010 | 10:22 PM
Thanks Punkenduro thats all I wanted was an educated guess.
Cheers Jim
cegusman
Jun 15, 2011 06:49 PM
caasI
Oct 10, 2008 09:43 PM
KLXer
Feb 10, 2007 12:42 PM
cwgoff
Feb 1, 2007 01:35 PM
bryantjt
Aug 30, 2006 03:09 PM
