Tube failure question
Old May 12, 2009 | 02:49 AM
FM_Thumper's Avatar
Originally Posted by Nobrakes
I just put 'em on finger tight. Tighten down the valve cap finger tight, and then "unscrew" the valve stem nut up against it finger tight.
Really? So the nut is not against the wheel at all but against the plastic valve caps? Is it ok to ride like that in the street at highway speeds as well?
Old May 12, 2009 | 03:07 AM
MaverickAus's Avatar
I do ...
Old May 12, 2009 | 03:11 AM
OK heres my story, one day out trail riding in wet conditions I could not get up a hill (stock 603's) I lowered the tyre pressure, got up the hill fine but ripped a tube. When I got home I bought rim lock and a h/d tube and put them in, only problem then was the wheel was out of balance over 50mph so I had it balanced. Another time was going up a dry but steep hill and ripped the tube, bought another h/d tube and was told to leave my valve stem nut loose up against the cap like Nobrakes and I said before. Since then I have had zero problems with tubes or tyres. I have since replaced the 603 with a knobby tyre and still to date have had no problems.
So to sum it up I installed h/d tube, 1 rimlock in the back wheel with balancing weights (only needed if going over 50mph) and leave my valve stem nut loose.
Old May 12, 2009 | 03:26 AM
KDXmike's Avatar
Yes it came stock with one rim lock front and rear. I drilled the rims and added the second one, though.
That's the way A KLX250S should be stock. At least a rim lock on the rear wheel. I know your KTM has greater dissplacement than the KLX but my son's CRF150F has a stock rear rim lock.
So guys, get a rim lock and balance that beeotch out. We're ripping stems with a stock KLX250S. Add the mods for more power and you're just asking for a ripped stem.
Mike
Old May 12, 2009 | 12:47 PM
roadglider's Avatar
KDX mike thanks for the info. It's nice to have a starting point for the weight.I'm still not sure yet if I'll use the weights or just get another rim lock. Like 2K1w=no$ said if your going to have that much weight it might as well do something. However the weights would definately be less hassel than removing the wheel,tire and drilling the rim. With the "awesome" power of the stock KLX one rim lock would be fine.
cegusman
Jun 15, 2011 06:49 PM
RODDISM
Ninja ZX-14
Jul 13, 2008 04:01 PM
DABBE
Ninja ZX-10R
Apr 6, 2008 07:22 PM
Hawk
Jul 15, 2007 12:35 AM
xyz1000rr
Jan 28, 2007 02:28 AM
