True power curve? 351
the 01 that my son has(used to be mine) made 375hp /885tq
the 06 I have now is just over 500hp & pushing 1020tq ---
scale was only cal'd for 1000.the staight 6's are torque monsters and it starts down low where & when you need it the most.
My gas powered V6 puts out 420 ft/lb at 2500 RPM. 90% peak torque between 1700 and 5000 RPM. Very flat torque curve. And it will get 25 mpg. It only makes 365 HP though.
If you ever rode a trials bike you would understand when it is not so good to short shift. They have a bizarre transmission, at least until you consider what is needed. They have an extremely close first three gears, then a huge jump to the next few gears. The reason is they use the first three gears in the sections, the top gears are for the fast riding between sections. On my Sherpa T one has to rev third gear out a fair amount to not be so low as to bog when shifting to fourth.
But that is all beside the point, I was just buggin' ya! I know what you're saying. You don't want to rev hard if you don't have to. It is nice to know that reserve is still there if needed though.
Then there was the 650 big bore using the Vulcan piston... No absolute numbers, but the compression is probably similar to the OEM 650, just a bigger bore - and more torque through the entire power range. We knew so since we actually could do a head to head comparison. The big bore pulled the stock bike. My big bore with a pipe, snorkel pulled, and a Dial-A-Jet compared to a similar bike with only the big bore and no snorkel got pulled by the stock big bore at the start, but within a short distance started to walk away - quickly. I like power all the way through, not just at the top. That is where I use it and where I need it. No peaky runners in my garage.
I would love a diesel mx bike...
