Throttle tube.
Old Apr 23, 2009 | 09:03 PM
rmkmod's Avatar
Default Throttle tube.
I would like to change my twist throttle for something that has less twist, like a comp bike, is this possible, if so whats needed, just a different throttle tube? Thanks.
Old Apr 23, 2009 | 09:27 PM
Yes there is one somewhere, I think someone on here put one on. Oh welcome to the forums. There will be someone on soon with an answer. Oh have you tried the search feature. Here let me give it a shot.
https://www.kawasakiforums.com/forum...searchid=86044
I typed in quarter turn, and then did the advanced search and picked the KLX 250S section. Works every time.
Old Apr 23, 2009 | 09:30 PM
Old Apr 23, 2009 | 11:20 PM
Sid Post's Avatar
How about some replacement switch gear? My horn blasts intermittently as I bounce down our rough asphalt roads.
Old Apr 24, 2009 | 12:29 AM
Take it apart and clean it. And yes clean is the answer to everything.
Old Apr 24, 2009 | 12:48 AM
Sid Post's Avatar
My problem is more then road grime. The plastic is shot. The turn signal is hard to use and the Hi/Low beam switch just makes the whole thing spin around the handle bar.
MotionPro has a good 1/4 turn throttle. I just wish I had something better then the cheesy plastic switch gear that came on my ride from the factory.
Old Apr 24, 2009 | 02:43 AM
maineack bob's Avatar
i was considdering the vortex but i read up on it and knodised that they make the turbo to fit the klx 300r so maby that will fit the klx 250 aswell... has anyone tried the turbo on their klx? id like the quicker throtle but im not sure if the vortex would be to quick
Old Apr 24, 2009 | 04:42 AM
Xplosivo1's Avatar
any links to info on the turbo?
Old Apr 24, 2009 | 05:36 AM
NEWPARTSRULE's Avatar
Sid, Check out Baja Design or Trail Tech for a switch. bob, I don't know squat about the turbo, but the vortex is much quicker than stock. It has a plastic tube but a few mechanics that I respect told me they have never seen one break. Moose makes a metal sleeve\tube for the vortex and I think the turbo, also. Xplosivo1, try hooking up to Motion Pro's site.?
Old Apr 24, 2009 | 07:19 AM
Xplosivo1's Avatar
Thanks new parts, just look up the info!
