Throttle tube.
Yes there is one somewhere, I think someone on here put one on. Oh welcome to the forums. There will be someone on soon with an answer. Oh have you tried the search feature. Here let me give it a shot.
https://www.kawasakiforums.com/forum...searchid=86044
I typed in quarter turn, and then did the advanced search and picked the KLX 250S section. Works every time.
My problem is more then road grime. The plastic is shot. The turn signal is hard to use and the Hi/Low beam switch just makes the whole thing spin around the handle bar.MotionPro has a good 1/4 turn throttle. I just wish I had something better then the cheesy plastic switch gear that came on my ride from the factory.
i was considdering the vortex but i read up on it and knodised that they make the turbo to fit the klx 300r so maby that will fit the klx 250 aswell... has anyone tried the turbo on their klx? id like the quicker throtle but im not sure if the vortex would be to quick
Sid, Check out Baja Design or Trail Tech for a switch. bob, I don't know squat about the turbo, but the vortex is much quicker than stock. It has a plastic tube but a few mechanics that I respect told me they have never seen one break. Moose makes a metal sleeve\tube for the vortex and I think the turbo, also. Xplosivo1, try hooking up to Motion Pro's site.?
