three five one, almost done!
Old Mar 22, 2010 | 06:15 AM
mauirider's Avatar
Thumbs up three five one, almost done!
Woo hoo, 351 klx 250sf, almost done. All put together, and I started it up just at dark. I warmed it up for a few minutes and changed the oil. It's not idling, I will have to trouble shoot this, and then start to break 'er in! Very stoked about the fact that it doesn't appear that I messed up and it started.
Got all the smog stuff off. I read one thread that mentioned to use a hose clamp to compress the rings. I didn't want to chance scratches, so I used a big zip tie, slipped the cylinder on and then clipped the zip tie. Worked great.
Thanks again to you guys who gave input and guidance.
attached photos- old n new cylinder an piston, 351 cylinder on the bike.
Break in later this week!
Attached Thumbnails three five one, almost done!-img_2360.jpg   three five one, almost done!-img_2356.jpg
Old Mar 22, 2010 | 06:46 AM
punkenduro09's Avatar
glad to hear it went on with no trouble. cant wait to do this my self one day.
Old Mar 22, 2010 | 09:31 PM
Congrats on the successful install, that's gotta be a good feeling to hear it pop off. Good pics too.
It's not easy but I'm waiting untill after an upcoming D/S ride to install my 351. I want some time after the install to get it dialed in.
Dan
Old Mar 22, 2010 | 11:05 PM
armycopter's Avatar
dan888, I know what you mean, I had my kit sitting on my shelf for over 6 months! It was a tough wait.
Old Mar 24, 2010 | 09:42 PM
mauirider's Avatar
Wow, I just took the finished 351 out for the first spin.... still smiling for sure.. this bike now fully rips! Anyone who is even thinking about it, don't hesitate.
Old Mar 24, 2010 | 11:30 PM
armycopter's Avatar
what notch is your needle on and how many turns do you have on the A/F screw?
Old Mar 25, 2010 | 06:20 AM
mauirider's Avatar
I didn't change the needle since I added the slip on a month or so back. It is in the middle. Have read that a lot of guys are pulling the needle up by placing the clip in the 4th groove down from the top. Have noticed today that the popping on decel is much less now that I have put in the #40 pilot jet. Got 40 miles on the 351 kit as break in today. The logic of the "motoman" break in technique seems sound so that is what i did. Ran her hard immediatly after the first warm up.
Old Mar 25, 2010 | 02:21 PM
armycopter's Avatar
Thanks I have the 132/40 setup as well. My needle is on the 3rd clip. Although I do have two washers per the dyno jet instructions. My popping seems to have reduced quite a bit now that I'm running 93 octane. Not sure if that's what helped it or something else. I've got about 40 miles on my BB kit as well. After two warm up cycles and 10 miles of easy throttle, I'm riding it normally. Haven't hit the rev limiter or anything but I haven't really been holding back. Seems to run great. I plan to pull the plug this weekend just to see what it looks like and change the oil/filter at the same time.
Old Mar 26, 2010 | 03:46 AM
mauirider's Avatar
Very cool, armycopter... As i mentioned I just decided to rev it hard and do compression decel to brake it in. You id see the 'motoman' recommendation on break in? I'm also very pleased with the uncluttered look with all the smog tubes removed.
klx250s_rider
Aug 29, 2007 09:07 PM
CRAZY
Aug 18, 2007 12:26 AM
firstninjabike
Aug 30, 2006 06:06 AM
arrowwhead
Mar 8, 2006 09:47 PM
littledevil
Feb 5, 2006 10:43 AM
