There Must Be a Severe Grease Shortage!
Old Dec 20, 2006 | 05:38 AM
Default RE: There Must Be a Severe Grease Shortage!
And the award for the oldest post to be resurrected goes to........Marty. Just kidding, its nice to see the great information being recycled. Hmmmm maybe that's what we can call you Marty, Father time recycled..........OK that was stupid, .....as you were.
Old Dec 20, 2006 | 12:41 PM
Ya have to bring old stuff up every now and again....there is alot of newbee's around here..... The wheel bearings come out of the hub, you have to knock them out from the opposite side, says the service manual. So how much grease would they need?
Old Dec 21, 2006 | 02:00 AM
MaverickAus's Avatar
ORIGINAL: EMS_0525
ORIGINAL:klxstiffler
i'm pretty sure the wheel bearings are sealed, which means you can't actually grease inside them.
Old Dec 22, 2006 | 01:09 AM
YYY.GUY's Avatar
The manual seems to indicate the bearings have a shield, and doesn't mention anything about greasing them. It says they can be inspected in place, but if they're removed, they should be replaced rather than reinstalled.
Old Dec 22, 2006 | 12:51 PM
Yea im gonna call the shop and talk to the mechanic on this, see what they do. I also couldnt find moly b grease at the autoparts store, i got some high temp wheel bearing grease, i believe its lithium based... is that the wrong stuff... will it hurt to use it?
Old Dec 22, 2006 | 04:44 PM
Moly grease is for assembling engine parts, ie new cams, certain bolts etc., it is designed to dissolve when the engine and oil gets hot.
The Manual does not specify a particular grease for the axles and the speedo thing. I use the same marine grease that I use on my outboards and boat trailer bearings. Great stuff, besides I've been known to take a jaunt on the beach, so myklxis familiar salt water.
YYY is right about having to replace bearings if removed, well thats what the manual says.
Old Dec 22, 2006 | 04:57 PM
Would you just be able to grease them still in the hub? remove the seal and try to get as much in as possible? My tires are on my front port at home, so i will be doing this shortly...
Old Dec 22, 2006 | 05:05 PM
Well, I don't see how you could get grease in the bearings, as they are sealed. I just clean them up real good (wipe off salt and sand) with a rag, make sure they spin nice and smooth, and slather (technical term) them and the axle with marine grease. We're not talking rocket science here.
Old Dec 22, 2006 | 05:14 PM
ORIGINAL: Finger Mullet
ok you dont see how to grease them, but you have greased them? u confused me.....is it just me? do you grease the axle, maybe?
Old Dec 22, 2006 | 05:35 PM
DirtSurfer's Avatar
My understanding and experience with prior bikes (and skateboards...) is that you don’t ever grease sealed bearings. When they go bad (start to make noise or in a worst case scenario, freeze up) you replace them.
I have never greased my axles since the load and rotation is transferred to the bearings. In my opinion greasing the axle would just be creating a dirt/sand magnet in your wheel[][] .
Considering where you’re headed the first of the year, I’d recommend keeping that axle clean and clear of grease….[8D]
Hope that helps..
